R32 Gtr mega sale
I have a few Gtrs that i have wrecked and these parts are taking up a lot of space
All parts are from or fit to R32 Gtr unless it says otherwise
Interior:
Seats $300 pair
Dodgy drivers
Passengers in awesome condition
Driver's door card $60
Centre console $40
Inner guards $100 pair
Door sill trims $20 pair
A pillars $100 pair
Kick panels $10 each
Triple gauge cluster $60
Steering column $50
Ignition barrel $100 with key
Indicator stalk $40
Nardi steering wheel with boss kit $60
the right hand side is a tad warn in the pick
Map light $30
Interior roof light $30
Sun visors $30 pair
Engines/drivetrain
Rb26dett complete motor $3000
Complete engine with good compression what you see in the pic is what you get (has all intake and turbos),wiring loom, alternator etc, bolt in and drive away
Rb26/30dett complete motor $4000
rebuilt stock bottom end, intake, exhaust steel wheeled turbos, new timing belt, rwd sump, new gaskets etc
Rb26dett complete engine $1,800
This was in my race car however was never used as I noticed the oil pressure was low, missing turbos now however complete intake is there and exhaust manifolds (ran well, probably just needs an oil pump and a check)
Imagine a complete motor minus turbos
Gearbox in good nic $500
Stock tail shaft $50
Trust manifold $800
This is a twin t67 manifold
ABS unit $150
Attessa pump $50
Power steering pump $70
Complete aircon setup $150
Power steering rack $100
Front diff with welded on extension(you don't get the lsd centre just the casing) $200
Stock front diff with diff centre $250
Front drive shafts $100 each
Front hubs $80 for the pair
Lower control arms $50 (pair)
Entire rear end $800 (this is the entire rear cradle and everything in it)
Race modified front cradles $350
Brake booster $80
Exhausts:
Standard front pipes $70
Stainless steel aftermarket front pipes $200 perfect condition
Radiators:
Stock radiator (no shroud) $100
M spec alloy radiator $80
Electronics:
Apexi Power FC (rb26) no hand controller $650
Fuel Setups:
1000cc rochester injectors $400
Jap fuel rail twin in one out alloy with fitings and fuel reg $300
Fuel setup 1
044 pump
Earls fitting
$300
Fuel setup 2
040 pump
$250 has relay
Brakes/suspension:
R33 Gtr Brembo front setup $1250
Includes slotted rotor/braided line and new Ferodo 2500 pads
Tanabe suspension height and rebound adjustable need a clean but work well $400
R32 Gtr factory stock suspension $400 (perfect condition)
Located lower Blue Mountains, Sydney
Pick up preferred however can post at buyer's expense
Pete
0448468884
https://www.sau.com.au/forums/topic/369778-r32-wrecking-and-mega-garage-sale/
Intercoolers:
Trust intercooler $400
big arse intercooler(trust drag core) with custom piping suit $700
Aftermarket intercooler(massive)and trust/HKS pipe kit $500
Greddy Type R plumback setup $350
External
Colour coded items GUNMETAL GREY:
Rear bar $170
Stock side skirts including front pods $100
(the little pods in the picture aren't included)
Colour coded items BLACK:
Passenger side front guard $100
No dents but some scratches, overall good condition
Doors scratched but all there and straight
Bonnet with N1 lip(genuine made of rubber), minor scratches and some paint peel $350
Colour coded items WHITE:
Tail light driver side only $40
Doors- wrecking driver and passenger white doors with side intrusion bars, bar shell of door $50 each.
Happy to strip individual parts as needed (PM me with what you are after including a photo if you can and I'll let you know a price)
Side Mirrors $50 each
Front windscreen $200
Rear window $150
Rear quarter windows $50 each
Rims:
Modena 17x9 +25 Gtr offset $600
Panasport Cr5 17X8 Gtr offset $700
Panasport G7 17x9 +22 Gtr offset $1600
Panaport G7 (suit gts) $1200
Koya Inox Drifter 18x8 +34 (suit gts) $700
Rims are as new with expensive Maaxis rubber
Volks 17X9 +22 Gtr offset $700
Almost new Yokohama DNA rubber
R34 Gtr rims (white) 1400, no rubber
Located in lower Blue Mountains Sydney
Pick up or can post at buyer's expense
Pete 0448468884
hey fatz is the modena multi stud? looking at 4 stud rims.
5 stud
however i do have a pair of 4 stud 17" modenas in the same style for sale as well if you're interested
Air Con Panel
Still have? Condition?
Les ... 0417 123 053
no sorry sold already
hey mate would u have some STANDARD oil return lines that u would like to sell off ???
no sorry
Pete, you wouldnt have any RB26 covers that you want to sell would you?
I am after a full set
i do have a set they come with and engine or 3k
lol
Fatz,
You still have:
1. Climate Control panel?
2. Centre Console Surround?
3. Triple Gauges?
Les .. 0417 123 053
les i do have a triple guage cluster $50 or 60 delivered
