Story thus far: I'm putting my stereo system back in my R33 GTS-T, but I've never had the sub box bolted down in the boot. It's pretty heavy, so it always just sat there and didn't move about too much unless I took fast corners in my car. This was handy in case I ever needed to take the box out, but I would like to do a proper install this time, with sub box bolted down to the boot floor.
Now the standard piece of wood / carpet underlay that comes with the car, has turned to shit over time (read: bent) and is too thin to bolt a sub box to. It's also too flimsy to support itself without the spare tyre sitting in the well supporting it.
Just curious if anyone has fashioned up a piece of wood, to level out the boot in their R33, making the boot floor perfectly flat for the purposes of installing a sub box, and how you went about doing it (what did you use as a template, type of wood, thickness etc.)?
Just use the existing floor bit as a template, but maybe go a tiny bit smaller everywhere to account for thicker wood not being able to bend into the spot.
You could get rid of your spare tyre (I would rather walk home than drive on that thing... looks like an absolute nightmare) and somehow secure the wood to the floor
I've done it, quite easy once you remove the factory trim.
Bit difficult to explain, but I have 2 pieces of 18mm MDF cut-out and screwed/glued to the left and right sides of the boot floor, sits perfect around the wheel arch/fuel filler neck "intrusion". This gives me a straight edge over-lapping the wheel well hole, under this ledge another 2 strips of MDF protrude about 15mm out either side, and support the big square panel that covers the spare wheel. So long as you use the same thickness material, the center panel is supported on the middle by the spare wheel.
Best bet for a template is cardboard, not box style ribbed cardboard, but the good thick stuff used for posters etc. Cut your material a tad bigger then trim to size accordingly.
Any help?
Edited by blk94r33
there was recently a thread in the cosmetic section (i think) that showed how to install a sub into the false wall next to the battery. maybe look into that, as you will have boot space aswell. unless ur sub is too big
I made a false floor for my old Prelude.
Used the factory carpet and traced around it on 2 pieces of mdf.
Cut it outand test fit, marked any spots that wouldn't clear and took off little bitsat a time till it all fit nicely.
Haven't looked in my Skyline boot in a little while but with the Prelude the tyre sat up a bit into the boot so I used some mdf cutoffs and stacked them to bring it up to the same height then liquid nails & actual nails them on as little feet.
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
