I could not find a replacement r35 cooler and have been concerned about putting the old one back in after the disintegration of my engine.
I ordered the PWR replacement but it is less than half the volume so i wont be using it.
I have pulled out the old one and pulled it apart.
This is what i have done and i want to know if its too much of a risk to reuse it.
I have flushed it with fuel
I have flushed it with turps
I have flushed it with degreaser
I have attached one end to a garden hose and left it running for 10 minutes.
I have reversed the sides and again left it running for 10 mins
I have thrown it into the pool and left it there overnight
I also understand that the direction of flow is from the cooler to the oil filter which should trap any micro particles that get in.
Anyone prepared to give further advice
https://www.sau.com.au/forums/topic/370579-advice-with-oil-cooler-needed/
I can't help with finding a gtr oil cooler (perhaps try Steve at Just Jap), but I never re-use an oil cooler from a motor that had a bearing problem. Too many little spaces in oil coolers, and it's a very expensive gamble.
I'd never buy or use a second hand cooler for the same reason.
yeah like duncan said. I personally would replace it. you've done everything humanly possible and as flow goes cooler to filter you should be fine (most systems go filter then cooler though so double check that?) but it's a big risk. there must be a better option for replacement.
we are probably all being a bit over cautious especially given the nature of your failure but I can't help but think if it were my car, i'd keep hunting out that replacement....
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
