hey guys just wondering what top end kits are people running i.e.
1. i would like to use the vct in the neo head so what oil pump and gears?
2. tomei do a range of pro and pon cams im thinking the of the pon cam type b????
3. also what springs and shims and retainers are people using for the cams
also does anyone have the specs on a argo h beam conrods????and what piston to suit
https://www.sau.com.au/forums/topic/370628-head/
i wouldnt be wasting to much money on the head, all you need to make that power is drop in cams, upgraded springs, and cam gears for fine tunning.
a GT35 turbo or equivalent would be all you need.
CP Pistons 9.0:1
argo pistons will be fine check with engine builder for specs.
you should also keep in mind the costs of block & crank prep work. around that $1500.
before you start sending any blocks away have a clutch pressure plate, flywheel and the harmonic balancer sent to the machine shop with the block & crank to be balanced all together.
i get my machine shop to supply my with the correct bearing to suit.
https://www.sau.com.au/forums/topic/370628-head/#findComment-5915346
CP Pistons 9.0:1
hey thanks for getting back to me so quickly :) so are u saying that the valves and buckets+ shims are good for that much power? i have cam gears already
also i sent argo an email about there rb30 h rods and i worked out that there .160 thou smaller then my machinist said to get can anyone confirm that will be ok??
as for prep work my mate is the machinist lol and block was free (winning)
as for the clutch and flywheel is it rb30 or 25
https://www.sau.com.au/forums/topic/370628-head/#findComment-5916462
look has no one finished building there 25/30
1. i would like to use the vct in the neo head so what oil pump and gears in oil pump?
2. tomei do a range of pon cams im thinking the of the pon cam type b???? any used them???
3. also what springs and shims and retainers are people using for the cams in the neo head???
also does anyone have the specs on a argo h beam conrods????and what piston to suit or rods for about 700hp or more?
https://www.sau.com.au/forums/topic/370628-head/#findComment-5918120
Any aftermarket oil pump will do the trick. Tomei, Jun, HKS, Nitto or any other brand name pump. They all flow a shitload more then standard and will do the job fine. You will just need to get a collar.
You can get the tomei valve springs if they make them to suit the neo head. Tomei cams are fine. IVe only ever used the type a poncams. But cant see why the type b wont work. The Supertech valve train gear is great too. Especially since the dollar is so good atm. Not sure if they have stuff to suit the neo head though. I think thats the limiting factor with the neo head is lack of aftermarket parts in comparison to the rb25det head and 26 head.
What sort of specs are you after exactly on the H beam rods? Virtually any aftermarket rod will suit, so long as its for an RB30, Spool, eagle, argo, nitto whatever. The power you are going for is not that big that it warrants anything special. Piston choice is much the same. CP's will be fine, JE's or Ross or whatever your choice.
If you are using the rb25 gearbox, then use all your rb25 clutch and flywheel gear.
https://www.sau.com.au/forums/topic/370628-head/#findComment-5918582
It's also a fairly loose power guide mate. A turbo to suite 500hp is vey different to 700hp. Eg. Gt35 wod be best for your 500hp goal, but won't do a whole lot more very comfortably. T04z will get you 600hp at the wheels, but will be a fair bit more lag compared to a gt35. And still, a t04z won't get you to 700hp. The engine build involved is the same for those targets, but the different turbos will make for a completely different car to drive. If it were me I'd stick to 500hp as I still like a little bit of response.
Nitto oil pump would b my choice as well. Heaps of praise around the forums for them.
I think te bigger factor rather then what pistons and rods you choose is how well it's put together.
Is this car for street or track?
https://www.sau.com.au/forums/topic/370628-head/#findComment-5918679
also just getting spool rods for the bottom
do u know arias are a good brand Part Num:ap332104 does it suit the neo or do u have the part number for CP's, je's, Ross ????
cheers
street and track lol and yer turbo choice is going thro my head right now
im thinking about the nitto range
https://www.sau.com.au/forums/topic/370628-head/#findComment-5923694
cheers
for track work make sure an enlarged and gated sump is part of the parts list, even the best built engine wont last long without oil pressure.
https://www.sau.com.au/forums/topic/370628-head/#findComment-5925549
CP Pistons 9.0:1
Be careful with piston choice if you are using a neo head as they have smaller combustion chambers.
Type B 260 deg poncams give a slightly lumpy idle but seem to make more power everywhere on a 25 so they should be fine.
https://www.sau.com.au/forums/topic/370628-head/#findComment-5926683
    • I certainly fall into the annoyed camp, but glad to hear that if it's happening at low boost then I'm not likely going to blow a turbo and end up with metal shards in my oil. Just feels like it prevents me from really driving it without hesitation and "peak" performance. Wonder if it's the VCAM, it did an impressive job of shifting the torque curve and faster spool, but maybe now it's "too fast" and there's too much air for how open the throttle is.  Based on some other threads, will also do some reading on synchronizing the actuators. They are the default actuators that come on the Garrett's and I would think they would be set the same coming from the factory, but if the turbos don't actually work exactly the same way at the same time as previously mentioned, it would be worth making sure the actuators are actuating together properly
    • I went down this rabbit hole before, ended up sourcing a motor from the UK (I'm in Japan) which also didn't function correctly. With the original motor, I disassembled it and reassembled it and it works somewhat, sometimes. What I could deduce from all my screwing around is that there is calibration of the gears on the inside of the motor and two ramps on the main gear which activate switches that operate the motor and move the sunroof either to retract into the roof or tilt. Where I got stuck was that, it seemed in my case that one or both of the switches that are activated by the ramp on the gear did not always activate and thus the motor did not move, causing it to sometimes not retract or tilt (apologies, I've forgotten which way it didn't work.).  Of course this part is discontinued at Nissan now, it's the same part in the S15 but no other models. I also contacted the manufacturer of the component for schematics - forgot the name, they're based in Gifu - but they declined to share the information due to being bound by an NDA, sadly. Looking through my pictures now, it seems I last had a crack at this in 2022. See, I so kindly wrote "open" and "close" next to the switches. If you figure it out, please do tell me. Those little switches, with the red buttons may need to be replaced.
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
