hey guys just wondering what top end kits are people running i.e.
1. i would like to use the vct in the neo head so what oil pump and gears?
2. tomei do a range of pro and pon cams im thinking the of the pon cam type b????
3. also what springs and shims and retainers are people using for the cams
also does anyone have the specs on a argo h beam conrods????and what piston to suit
https://www.sau.com.au/forums/topic/370628-head/
i wouldnt be wasting to much money on the head, all you need to make that power is drop in cams, upgraded springs, and cam gears for fine tunning.
a GT35 turbo or equivalent would be all you need.
CP Pistons 9.0:1
argo pistons will be fine check with engine builder for specs.
you should also keep in mind the costs of block & crank prep work. around that $1500.
before you start sending any blocks away have a clutch pressure plate, flywheel and the harmonic balancer sent to the machine shop with the block & crank to be balanced all together.
i get my machine shop to supply my with the correct bearing to suit.
https://www.sau.com.au/forums/topic/370628-head/#findComment-5915346
CP Pistons 9.0:1
hey thanks for getting back to me so quickly :) so are u saying that the valves and buckets+ shims are good for that much power? i have cam gears already
also i sent argo an email about there rb30 h rods and i worked out that there .160 thou smaller then my machinist said to get can anyone confirm that will be ok??
as for prep work my mate is the machinist lol and block was free (winning)
as for the clutch and flywheel is it rb30 or 25
https://www.sau.com.au/forums/topic/370628-head/#findComment-5916462
look has no one finished building there 25/30
1. i would like to use the vct in the neo head so what oil pump and gears in oil pump?
2. tomei do a range of pon cams im thinking the of the pon cam type b???? any used them???
3. also what springs and shims and retainers are people using for the cams in the neo head???
also does anyone have the specs on a argo h beam conrods????and what piston to suit or rods for about 700hp or more?
https://www.sau.com.au/forums/topic/370628-head/#findComment-5918120
Any aftermarket oil pump will do the trick. Tomei, Jun, HKS, Nitto or any other brand name pump. They all flow a shitload more then standard and will do the job fine. You will just need to get a collar.
You can get the tomei valve springs if they make them to suit the neo head. Tomei cams are fine. IVe only ever used the type a poncams. But cant see why the type b wont work. The Supertech valve train gear is great too. Especially since the dollar is so good atm. Not sure if they have stuff to suit the neo head though. I think thats the limiting factor with the neo head is lack of aftermarket parts in comparison to the rb25det head and 26 head.
What sort of specs are you after exactly on the H beam rods? Virtually any aftermarket rod will suit, so long as its for an RB30, Spool, eagle, argo, nitto whatever. The power you are going for is not that big that it warrants anything special. Piston choice is much the same. CP's will be fine, JE's or Ross or whatever your choice.
If you are using the rb25 gearbox, then use all your rb25 clutch and flywheel gear.
https://www.sau.com.au/forums/topic/370628-head/#findComment-5918582
It's also a fairly loose power guide mate. A turbo to suite 500hp is vey different to 700hp. Eg. Gt35 wod be best for your 500hp goal, but won't do a whole lot more very comfortably. T04z will get you 600hp at the wheels, but will be a fair bit more lag compared to a gt35. And still, a t04z won't get you to 700hp. The engine build involved is the same for those targets, but the different turbos will make for a completely different car to drive. If it were me I'd stick to 500hp as I still like a little bit of response.
Nitto oil pump would b my choice as well. Heaps of praise around the forums for them.
I think te bigger factor rather then what pistons and rods you choose is how well it's put together.
Is this car for street or track?
https://www.sau.com.au/forums/topic/370628-head/#findComment-5918679
also just getting spool rods for the bottom
do u know arias are a good brand Part Num:ap332104 does it suit the neo or do u have the part number for CP's, je's, Ross ????
cheers
street and track lol and yer turbo choice is going thro my head right now
im thinking about the nitto range
https://www.sau.com.au/forums/topic/370628-head/#findComment-5923694
cheers
for track work make sure an enlarged and gated sump is part of the parts list, even the best built engine wont last long without oil pressure.
https://www.sau.com.au/forums/topic/370628-head/#findComment-5925549
CP Pistons 9.0:1
Be careful with piston choice if you are using a neo head as they have smaller combustion chambers.
Type B 260 deg poncams give a slightly lumpy idle but seem to make more power everywhere on a 25 so they should be fine.
https://www.sau.com.au/forums/topic/370628-head/#findComment-5926683
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
