  • 3 weeks later...
So its been a couple of 100 k's so i thought id post my final thoughts.. still running it in the original location.. no problems holding boost to redline now. i must say i am in LOVE! this has totally transformed the car! the thing is so much fun now! it must have taken a little while for the computer to learn though it is so nice to drive with plenty of grunt!
I highly recommend this 2 minute mod to anyone still running the factory boost controller. and no error at all for not having it plugged in.
Edited by Sage222
Do the M35's have a "Solenoid valve control system (common on Nissan and Mitsubishi vehicles)"? (As per: http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_id=15262)
I really want to get my I-color installed tonight, just can't get my head around this shit. :stupid:
Slightly out of my depth here; but I would say so.
There is a stock solenoid that takes in a boost line (comes off a T) and then plumbs back into the intake behind the AFM. IMPUL gave me a nice hand drawn diagram of this (their suggestion to me was to bypass the solenoid – thus the reason for the diagram) but if you’re not sure where the lines are then this should make it reasonably clear. Ive removed the unnecessary Japanese text and arrows in the diagram. Its drawn from the perspective of standing on the passenger side looking down (birds eye view) at the engine. Far left hand side is thus the front of the car – the box at the bottom is the air filter box etc.
Tried to keep it all looking fairly factory so I kept the T piece. Confident that the other Blitz Valve Unit is setup right, just wanted to check that these lines are ok. (Will be putting them under all the cabling after, just had them up top for the photo)
Apologies for the shit photo. I have a crap phone and a not so steady hand.
Edited by jasevr4
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
