Hey guys,
I used to have a gym membership, but I always found it too much effort to actually 'go' to the gym, so my money was getting wasted.
For about the past 6 months I've been working out at home, for me it works much better, the only problem is its difficult to exercise some muscles properly
We have here:
-Dumbells
-A barbell
-Bench press (also does incline etc)
I'm also hopefully buying some sort of setup that will allow me to do lat pulldowns soon
Anyways, these days my workout consists of:
-5km run
-3 sets of 10 diamond pushups
-3 sets of 10 incline bench press
-3 sets of 10 bicep curls
-3 sets of 10, erm, dunno what you call them but you hold your arms bent in front of you and raise them at a 45 degree angle upwards and outwards, works your shoulders + delts
-3 sets of 10 dumbell bent-over row
I do that 3x a week, plus I do an abdominal workout 2-3 times a week on my rest days.
I am a skinny bastard (63kg hah), but after about 4 months of hitting it hard its fiiinally starting to show some results :)
Anyone else got some good excercises for around the house?
https://www.sau.com.au/forums/topic/370749-working-out-at-home/
  • Replies 41
These are exercises that I like to do with dumbbells (I workout at home as well)
DB Flyes
DB Press
DB Bicep Curl
DB Zottman Curl
DB Shoulder Press
DB Arnold Press
DB Squat
DB Upright Rows
DB Rear Lunge
DB Shrug
Goto bodybuilding.com if you want to know what that are etc.
-5km run
someone already suggested it but just get one of those towers so you can do pull ups and dips
you don't have any exercises for your side delts so throw some laterals in there... standing
throw some overhead presses in there (dumbells or barbell) and some upright rows (for your traps)... maybe work up to some power-cleans, but be careful with form
but most importantly you need to strengthen the posterior chain (your back/spine)... so deadlifts and good mornings... this will help all your other lifts
no leg work?
I can't wait til I get my home gym up and running... I find I get a better workout at home but I'm not setup properly yet so its off to the gym for me:(
At home to keep up interest, try to always run two things simultaneously.
1) Physical routine &
2) Mental stimulus, fun & preoccupation
Without the latter, it's hard slog.
Motivation is a killer.
comes to 7:30pm at night and you can train or watch tv. damn that tv
For lats just buy a power tower i think they are called. Can do chin ups and dips on them. Best investment ever, do eet
edit: something along these lines here
Jebus, $400?? Anyone know of any cheaper ones? Heh.
no leg work?
Cheers man, some good advice in there. Yeah no leg work yet because after running 5km they are shattered. I might try some squats now though. As it is after this workout I end up shaking, can barely lift my arms to raise a glass haha.
Yea, sorry mate, that was just an example. I used to train at home and the one I have here cost me like $250 IIRC. I wouldn't recommend getting to cheap a tower because the really cheap ones usually flex around a little when you're doing dips on them. Not very inspiring...
Those tower 200 door gyms look like a good thing. Does anyone on here use one?
I'd love a gym at home again. Had to sell my setup when I moved house. Really can't be f**ked going to a gym to work out. I did for a while, nut found better gains and more motivation when working out at home.
I think I may buy me a tower 200!
So here's a question.. How the hell do you guys do squats at home? I managed to lift a 30kg barbell over my head, but I found actually doing the squats fairly easy. Upping the weight just made it impossible to lift over my head. Any ideas?
Clean and jerk the bar for front squats? I used to do dumbell squats...they were good for the traps too :)
yeah you really need some sort of rack... you can do the front squats or dumbell squats as has been suggested but if you want to go heavy you might have to go to the gym
there is a trick to using lighter weights at home but making the exercises harder... try to be really strict with your form and take 1-2 seconds in the positive movement and 4-6 seconds in the negative part... so for squats, squat down really slowly (it will feel strange going so slowly at first) and as deep as you can without losing your balance or lifting your heels or toes off the floor, then explode up... you can even turn it into a jumping squat when your comfortable with the weight
also try split squats with dumbells and even one legged squats... do a search on youtube for squat variations and take your pick
we did these last night and they suck... but you won't need a lot of weight at first so could be good for you... ignore the rack in the vid you could do these with your 30kg barbell and really feel it! I'm in pain today
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
