Hey guys,
I'm currently dealing with a fantastic overseas supplier who has offered me a great deal on OEM, Aftermarket Engine parts, Bodykits and MORE!!!
So post up what you want guys! and ill create a list and send it off to get a price!
they do all sorts of body kits too so just post up what you want!
They deal with such guys as Sam at GTMotorsports, Scott at Relentless Autosports, Tony at Motordyne Engineering and many more!
For any over seas orders the supplier has no problems tracking down all the parts and opening other avenues of inventory for you to get you the absolute overall best
price
on your purchases by packaging everything under one shipping label. It does not matter how many boxes we use, shipping companies use overall measurements of all the combined boxes and weight. So dont worry about (Example) your coilover system getting into a fight with your front bumper in the shipping box =P
For any more INFO PM me
https://www.sau.com.au/forums/topic/371305-overseas-order-for-parts/
  • Replies 40
so guys im about to hit them up,
v35 coupe
rear v35 pods
Nismov3 front bar
07 JDM tails
07 JDM Headlights
v35 sedan
y-back exhaust for sedan - 3' megan
v36 Sedan
stillen front spilitter for v36/g37
g37/v36 weathershields
Anyone else?
v35 coupe
rear v35 pods
Nismov3 front bar
07 JDM tails
reverse light switch (unsure on what this is)
OEM brake rotors for brembos
drivers side window motor
tein basic or super street coilovers
OEM Infiniti badging (both on rear boot)
OEM Infiniti Grille Badge
07 JDM Headlights
v35 sedan
v36 Sedan
v36 Coupe
IPL sideskirts
19' Stock wheels
UPDATED LIST SO FAR
Edited by Cobey
Out of the US, had no drama so far, received over $8,000 in stock
customs is watching then.
they will randomly open mine to check things.
given the list you have there I would get a customs number/broker if you are going to keep doing it. gov't will nab you as well if you are not careful.
Hi Cobey
If this is still on, I'd like a few things
2008/2009 v36 sedan
Eibach prokit springs( the ones that drop by approx 1 inch)
Hotchkis sway bars front and rear.
ARK cat back exhaust- not sure if the g37 over there will fit on a v36??
Phillip style DRL -the ones in below link.
http://store.ijdmtoy.com/Philips-Day-Light-LED-Daytime-Running-Lights-DRL-p/led_ddl_sku_7c.htm
cheers
oz.
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
