Hi guys,
I have searched a few times under a few different variations of heading and found nothing. All i need to do is remove my afm plug from the factory wiring and replace it with a newer better one. I was expecting the grey plasic plug to be half moulded and clipped together but it's a solid piece with a yellow insert. Am I right in assuming this Yellow insert is the key and if I remove that then the wiring will be able to come out freely? How do u do it without breaking it? The newer plug is second hand with a bit of wiring hanging out but would rather replace the lot rather than cut wires and solder then tape up.
Thanks in advance
Liam
https://www.sau.com.au/forums/topic/371345-changing-the-afm-plug-over/
A pic might help, there are lots of different plugs around.
Usually you squeeze the two sides in and it should pop out, the yellow part is the inner part of the plug, it also has an outside grey part over it.
When i got mine it was twisted together and then taped up!!!
Hi guys,
Thanks in advance
Liam
You are going to have to make the electrical joins at some point; while it's possible to disassemble the plug and
connect the pins to the wires, you will probably get a better result from doing what you prefer not to
(i.e. join where the breaks are with solder and heatshrink).
Cheers,
SW
Geeze its not rocket science.....
Those plugs can easily be disassembeled , you just need a few precision srew drivers to get in there.....bear in mind however some of them can be very brittle and dont matter what you do, it will break, so you better hope your replacement is in good nick.
Yes the yellow piece is what locks everything in place ,remove that first....
Experiment on the one you have to replace
The whole reason I am asking was because I have never done it or even attempted it before and I don't want to break them. Precision screw drivers? Is the yellow piece clipped in? Screwed in? Just sitting there? Again just how does the yellow piece come out? Thanks for the info but I'm none the wiser as to disassembling it.
Use a flat and pry up in the middle of the front....the whole portion needs to be lifted as you would see three tabs holding the yellow piece from coming out
While you are prying the front get a next small flat and place it in the back of the yellow piece from behind and push it out....try to do it evenly and you will need someone to hold it steady for you
When you get out the yellow piece there are three individual tabs holding each wire terminal in place
Pry these down while holding the wire from behind and pulling it out at the same time .....these need to be moved a good bit for it to come loose.
Waallllaaaaa....
Now reverse the whole process and lets head for the bar
then just fit some new plugs
PC computers usually have good connectors to suit this type of application with locking tabs
check out places like jaycar etc online to find a pair of male/female clips with a locking tab
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
