Even though the PFC has more cells to adjust the standard ECU calculates/interpolates better between them. I think the new HPI covered this subject come to think of it. The standard ECU takes TPS into the load calculation. Not sure if all PFC's do that? So if you got your cells as smooth as the PFC with the Nistune then is should calculate the load points better under dynamic conditions. In saying that I don't know if you can adjust the load points, ie if you can't what happens once you go above the standard redline?
That's pretty nifty.
Also interested to know what happens with NIStune chips in regards to exceeding redline and if there are load point adjustments...
What do you mean "exceeding redline"? The standard maps in Nissan ECUs usually have the last cells that are mapped at revs that are well lower than redline. If you want to be able to tune to higher revs, the very first thing you do is rescale the rpm scale. And, if you expect to be making more power than standard, you do the same to the load scale. This has been said before in this thread. And, the exact position of each point on the load and rpm scales is completely arbitrary. You can bunch them up near peak torque or boost transition and spread them out elsewhere, or you can make them equally spaced. Up to you.
The redline is exactly that. A separate number that you can set at any rpm you like. That might be well below the top of the map, or it might be not far after the top of the map (sensible) or it might be well higher than the top of the map's rpm scale (which could be dumb). Whatever, the ECU just does the rev cut at that point, regardless of what the mapping look like.
Edited by GTSBoy
By what I've read, the MAP sensor doesn't rely on air flow but it functions via air pressure which can lead to better response and power output once tuned correctly. D-Jetro also has launch control, fuel / ignition cut, anti-lag, NOS, etc which are some features you may or may not use.
I was going to take this path, but I wasn't aiming for high power so based on my findings and having a NIStune setup, the NIStune is the best bang for buck. Hit up a few searches and this will also confirm what I've just typed.
Power FC is 20 x 20 and NIStune is a 16 x 16 resolution so if it's a high RPM revving monster then PFC should be considered.
I remember reading that NIStune is tuned cell by cell at 500 RPM intervals, think it was ns.com though so take that with a grain of salt.
again with the mis info.
Djetro does not have launch control or ignition cut.
Nistune scaling can be tuned via whatever scale you input.... from 50rpm to 5000rpm...
and reading engine load by air pressure instead of hotwire airflow meter does not lead to better response or more power
hotwire airflow meter measures air directly passing through to give engine its load axis
manifold air pressure sensor measures pressure and guesses engine load based on pressure via a lookup table
when you reach target boost the manifold pressure sensor value remains fixed and you run 2d map from here on
when you reach target boost the airflow meter continues to increase and you run 3d map
Well, sort of. It is actually pretty easy to determine the relationship, for A GIVEN ENGINE, between MAP and air flow (with IAT correction). And it's not going to be much less accurate to calculate it like that than the error that a hotwire AFM will give anyway. Anyone who assumes that a hotwire is 100% accurate, even when brand new, is fooling themselves.
The problems with using MAP come when, for a given engine, you change things like cams or porting or exhaust, or anything that changes the way the engine breathes. This is why back in the day, with early EFI systems that only had MAP for a load reference, if you did any such mods the mixtures would all go to hell and you had to start tricking the system by putting in resistors on water temp sensors and so on. But with an AFM, if you make the same breathing mods, then the AFM just measures the air amount and the mixtures stay the same as original and it basically works OK.
But none of this matters a poop to anyone using a tunable ECU. Doesn't matter if you're using MAP, AFM or just TPS and revs as your load input. This is because even with MAP or TPS only, you don't actually want or need to calculate how much air is being ingested. You just change the multiplier (the value in the fuel map basically) to add or subtract fuel from what was there before to give the correct mixture and hey presto - it's tuned. On that basis, AFM and MAP are essentially equivalent in accuracy - and in reality, given that hot wires tend to get dirty and have their calibration drift over time whilst the basic breathing characteristic of the engine remains essentially the same, then MAP might even be more accurate over a longer period of time than AFM anyway. TPS and revs as load input sucks a bit by comparison, but we're not here to talk about that anyway.
Edited by GTSBoy
  • Like 1
Yeah I always thought a MAF gave your far more information than a MAP + air temp sensor. MAF tells you how much air there is, MAP + air temp lets you guess how much air there is.
another reason why its crazy not to run a AIT sensor with a map based ecu.... its seems nearly every microtech that comes in running like shit hasnt got one.... surely it should not be a an option when you buy one of these things... it should be included as std..
One fatal flaw in your theory.... on why map is better... have a think about what you've written.
Yeah just checked Google and NS. I can confirm I had fail searches! Thanks for the clear up.
PFC Pro only has launch control.
But I have some points I'd like to clear up too, perhaps STATUS can shed some light on this too:
@ PaulR33 - Your stating that MAP won't produce better results as oppossed with a MAF.
@ PaulR33, Rolls, GTSBoy - If a MAP sensor is based on a table with direct input then wouldn't you be able to tune it finer without having inaccuracies unlike the MAF? If MAP wasn't as good for performance then why is it incorporated with the the PFC D-Jetro (higher end) ECU package?
Sorry if it's starting to sway off-topic, but I believe the nitty gritty bits of information is important before laying cash out for either a PFC or NIStune.
Air pressure does not directly correlate to how much air you have, you need air temperature as well and you need to know load. That is why I believe it can be less accurate, obviously the maf sensor isn't perfect though and only has a certain range that it works in.
Basically Im under the impression that there is more guessing with a MAP + IAT to get a table that can plot load vs rpm in a way that will be correct in all situations. Someone feel free to correct me though, that was just my understanding.
Tuning resolution has very little to do with the accuracy of a tune. Dont ever let tuning resolution sway your judgement on what ecu to use.
The BA-FG V8 engine is speed density based and only uses 2 1x14 lookup tables to map the entire engine operation. And it still gets through euro3/4 emmissions compliance.
Absolutely and not absolutely. Correct about needing air temp - but that's just so you can get the density of the air right. The MAP signal (+ correction via IAT and any other little corrections that may be applied) effectively multiplied by rpm and with a factor for volumetric efficiency vs rpm IS your load signal.
There's no guessing. It is a calculation to turn MAP into "air quantity". That calculation is actually reasonably simple to implement, and as I said a few posts up, if you get the absolute answer of the calc a bit wrong (assuming we're talking about what happens with a modified engine), you just trim it out in the fuel map.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
