Hi everyone. Took my car down to Sydney Monday morning to Dart Automotive in Punchbowl to have bigger injectors and Power FC fitted as well and then tuned the Next morning. they also did a spark plug and oil change for me and I cannot speak highly enough of the good, friendly, honest, well priced service Jim and the guys at Dart gave me. I had to book my car in at very short notice (last Wednesday) due to another unnamed workshop stuffing me around at the last minute and having already booked non refundable accommodation in Sydney. I am very very pleased with the results of the tune etc. The car had only 3" apexi exhaust from dump pipes back and hks electronic boost controller, factory fuel pump, factory airbox and factory turbos when I took the car to Dart and it made 179.9kw at 4 wheels. After injectors and power fc were fitted (still using factory fuel pump, airbox and turbos) the car now makes 280.1kw at 4 wheels at 1.15bar. I am more than happy with the results and it is a totally different car to drive. I used well over a quarter of a tank of fuel less on the drive home too. I also had an upgrade fuel pump to fit but Jim said I'd be wasting my money with as the factory GTR pumps are very very good and capable of well over 300KW which he could easily have said I needed as it would mean more money for him to fit. I would recommend these guys to anyone and will definatly go back to them for any future upgrades.
  • Replies 69
Posted Images
Did they comment on the reliability of the turbos at that boost, and what can happen if they fail? If not, they did not do the right thing by you IMO.
Did he offer an opinion about the reliability of 10-12 year old fuel pumps?
Nice result after all the messing around you had!
As I said via pm tho, that much boost is asking for a dead motor for the sake of 20rwkw, I strongly urge you to consider lowering the boost to a safer level for longevity of turbos, and in turn your motor
I have known Jim for many many years and thought he was a little smarter than that
1.15 bar of boost on a ceramic turbo is destined for failure.
Give him a call and make sure thats what it was actually tuned for as the colder weather may very well be causing it to over boost out on the road.
Oops, correction... car was making 219.9kw at the wheels before computer and injectors. And the car was running 1.15 bar on high boost setting when I bought it and who knows how long for as exhaust and boost controller were on the car in lap
Oops, accidentally pressed add reply before I was finished. Exhaust and boost controller were on the car in Japan. And yes he did mention the fuel pump being 12 years old and said that if need be he would put my walbro pump in but factory pump is performing fine and probably better than the walbro anyway. As for the boost I'll call Jim and ask him but I imagine he has done enough tuning to not do something that's gonna cause damage.
wouldnt worry about your boost too much. Its a long on going debate.
I would comment on how long my car ran standard r32 turbos for (at more then 1 bar) which arnt as good as r34 units but it would just turn into a shit fight.
Basically, trust your tuner, hes probably done a lot more cars for a lot longer then keyboard tuners on here
im running 1.2 bar on stock R34 GTR turbos & made 247rwkw~
it lasted around 6 months (still going tho) just the seals are letting go and oil is leaking through and ending up leaking out of the air filter :(
gonna lower it down to 1bar till i save up enough $$ for -7 or -9s lol
good luck, i hope it doesn't blow a comp or turbine wheel on ya.
id change the stock fuel pump to something new. you can sell off the stock pump quite easily also.
^^ agreed, a fellow member on this forum and sau nsw member ran 21psi and only pulled 262 or so @ CRD.
well I guess everyone is entitled to they're opinions but I'm happy with the way the car is. Jims dyno is apparently de-tuned 20 kw for race cars or something so power readings are 20kw less on paper than actual power figure. So car On paper was 199kw before and 261kw after but Jim said actual power is about 280kw. Totally different car to drive and big difference In power. I can definatly feel the increase and was told car could have been pushed even further but he kept it safe. The power figures are on paper And I will post them soon. I'm not saying anyone's opinions or suggestions are wrong. I'm happy with the car and Jim definatly seems to know what he's talking about and doing so I have faith in his work aswell as researching positive feedback from others who have used dart before I went there.
Its one thing to be happy with the car now, but how happy are you going to be when the turbo falls apart...
I have seen R34's make 280rwkw on standard turbos whilst i was at Advan. Cant recall how much boost it was running though as it was many years ago.
260 is much more believeable, Sif claim it was 280 if the dyno said 260!
And to surcam, who cares how much you were running?
Have a read of the engine fail thread, or other threads about dead 26s
Whilst the turbos might not fail in every single case, some might be fine for years, there is enough information & users to prove turbo failure can kill your motor if they let go.
Bit silly IMO to want that extra 10-20rwkw with the extra 2-3psi when it could cost you a 5-8k rebuild, not worth the risk at all. But then some places don't care if it kills a motor in 2 years time as they can then blame wear and tear, and make a lazy 2-3k outta a motor rebuild etc.
(DISCLAIMER before e-rage: Not saying this is what Dart have done)
It's both shaft speed and heat. Also #6 runs a bit hotter and hence its usually the rear that goes.
I wonder what shaft speed is influenced by...
But riddle me this, its a 10+yr old car with a history you can't say was always say was safe... How do you know it will be "fine".
Is it worth that rebuild gamble?
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
