I have an expired AASA licence, but I'll be sending in the renewal papers tomorrow - Would it be a problem if I bring my current expired licence in on the day if they haven't sent out my new one in time?
  • Replies 244
Posted Images
call them if you dont receive it by thursday and they should give you a temp licence/licence number
I've just gotten my car back up and running after a 2year 'rest period' and would really like to participate in this - put me down for a spot and I'll fill out the paperwork this evening when I have my car club membership details handy.
Alright AASA form sent, e-mail sent with all entrance forms and payment made! Can't wait!
Will be good to see ya again Steve.
Yeah looking forward to it Russ, will be good to catch up - Hopefully I can give you a run for your money!
Hope you have a new clutch Steve :D
Haha clutch is going strong Ash! I guess we'll see how strong after Saturday :D Make sure you bring all your 'claimed' kilowatts this time! ;)
Payment just transferred and should be in the account tomorrow - forms will be emailed tonight once I get home and get my CAMS license and car club membership numbers.
Really looking forward to this - I had a blast at the last one I participated in with you guys.
Forms just emailed through!
haha excellent!
Have ~350rwkw at the moment, checked the other day. Had a feeling it was a bit down on power @ Heathcote ;)
Still does mad circle work!
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
