  • Replies 244
Posted Images
So I had a dream (nightmare) last night that I got to DECA and I had forgotten something and wasn't allowed to compete.
Just to confirm, all I need is the following? :
Entry form, faxed, paid and accepted and on the list.
AASA Club Licence Application Printed and Filled out, to be paid with $50 on Saturday Morning.
1kg CAMS Approved Fire Extinguisher, bolted to a bracket that I've made from 30mm x 3mm Aluminum strap going between my front bolts on the passenger seat.
Motorbike helmet is alright?
Jeans, Long sleeve top and fully covered shoes?
Anything else I need to do before I head up on Friday arvo?
Getting really excited now, every time I think of it I get a little grin going and people at work ask me why I look funny :(
I want 22c, still and dry. Bring on the dry weather, I wanna see what some of you guys can do :)
Looks like the wagons not going to be ready for the event.
" It'll be ready mate... definitely (Mechanic) "
Luckily Iv got plan B: The miss's Mini cooper S.
Dont worry Im paying for this one: cooking, cleaning, massages....Omg what have I got myself into..
better be a bloody good Deca.
The first thing on your list should have been a case of beer.
:domokun:
Otherwise the list looks good, just remember to have ALL loose items (incl spare tyre) removed for when you go through scrutineers.
I've lost count the amount of people I've sent back over the years for this like loosely bolted in Amps/Sub's & other various items in the boot. All it does is waste everyone's time holding up the morning ;)
:domokun:
Brews shall be purchased between the outskirts of Shep and the motel, don't you worry about that :thumbsup: My only concern is the capacity of the mini fridge not being a team player :cheers:
No subs, and my amp is bolted in pretty securely, they won't be going anywhere.
Are you saying the stock space saver, bolted in properly, needs to be removed? Will probably rip it out when I get to the motel for the weight anyway...
Pretty securely might not be enough mate.
When I've been doing it, people that have them drilled into the backing MDF where the battery is - get knocked back.
Simply because 99% of them I've been able to move the MDF by hand. Imagine a heavy amp doing the rounds should you end up in a spot of bother. Simply not worth a risk.
The Cooper S will be a great car for the skidpan. FWDs do awesome on the pan!
Finally Cams gets with the times...
except when i got to the end, it couldn't process the payment :mad: - will have to ring tmw.
the online app was very very clunky, definitely v1.0
Is it secure?
The requirement as per the supp regs is that it is secure.
How you mount it is your choice. So it cannot obviously be moving in any direction and work loose.
Are there any restrictions on filling up from drums of fuel at Deca? This is my first outing since converting the car to E85 and not being able to duck out the to the BP for Ultimate out of the pump, so I just want to make sure I don't break some rule if I need to crack a drum open to fill up.
Edited by ENGINR
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
