  • Replies 244
Posted Images
So I had a dream (nightmare) last night that I got to DECA and I had forgotten something and wasn't allowed to compete.
Just to confirm, all I need is the following? :
Entry form, faxed, paid and accepted and on the list.
AASA Club Licence Application Printed and Filled out, to be paid with $50 on Saturday Morning.
1kg CAMS Approved Fire Extinguisher, bolted to a bracket that I've made from 30mm x 3mm Aluminum strap going between my front bolts on the passenger seat.
Motorbike helmet is alright?
Jeans, Long sleeve top and fully covered shoes?
Anything else I need to do before I head up on Friday arvo?
Getting really excited now, every time I think of it I get a little grin going and people at work ask me why I look funny :(
I want 22c, still and dry. Bring on the dry weather, I wanna see what some of you guys can do :)
Looks like the wagons not going to be ready for the event.
" It'll be ready mate... definitely (Mechanic) "
Luckily Iv got plan B: The miss's Mini cooper S.
Dont worry Im paying for this one: cooking, cleaning, massages....Omg what have I got myself into..
better be a bloody good Deca.
The first thing on your list should have been a case of beer.
:domokun:
Otherwise the list looks good, just remember to have ALL loose items (incl spare tyre) removed for when you go through scrutineers.
I've lost count the amount of people I've sent back over the years for this like loosely bolted in Amps/Sub's & other various items in the boot. All it does is waste everyone's time holding up the morning ;)
:domokun:
Brews shall be purchased between the outskirts of Shep and the motel, don't you worry about that :thumbsup: My only concern is the capacity of the mini fridge not being a team player :cheers:
No subs, and my amp is bolted in pretty securely, they won't be going anywhere.
Are you saying the stock space saver, bolted in properly, needs to be removed? Will probably rip it out when I get to the motel for the weight anyway...
Pretty securely might not be enough mate.
When I've been doing it, people that have them drilled into the backing MDF where the battery is - get knocked back.
Simply because 99% of them I've been able to move the MDF by hand. Imagine a heavy amp doing the rounds should you end up in a spot of bother. Simply not worth a risk.
The Cooper S will be a great car for the skidpan. FWDs do awesome on the pan!
Finally Cams gets with the times...
except when i got to the end, it couldn't process the payment :mad: - will have to ring tmw.
the online app was very very clunky, definitely v1.0
Is it secure?
The requirement as per the supp regs is that it is secure.
How you mount it is your choice. So it cannot obviously be moving in any direction and work loose.
Are there any restrictions on filling up from drums of fuel at Deca? This is my first outing since converting the car to E85 and not being able to duck out the to the BP for Ultimate out of the pump, so I just want to make sure I don't break some rule if I need to crack a drum open to fill up.
Edited by ENGINR
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
