Amazing :D but to be fair, it is an RB28. On gate that is always going to sound incredible.
Fkn lol at the end of the vid :P
alright how about a GTR internalled 2.6L RB25DET
i dont see how people like the 2JZ note..
1JZ i can see
  • Replies 259
what is this faggotry??
1JZ sounds nice.
but 2JZ come on?
Well if you are going to quote non stock engines I raise you this:
When stock though JZs have a higher pitched note just due to the header/head design, if you listen to stock motors side by side you will see what I mean, a stock GTR sounds like ass to me, modded they sound great, but a stock JZ sounds nicer than a stock RB in my mind.
Also this:
Edited by Rolls
i dont like that 2J note at all but i guess you really like the high pitched racing noise.
i like really aggressive shit.
30 and higher is what i want.
this is wicked!
series 3 with full top secret kit and 1200HP
QLD represent aha
Mayb my phone ruins it. Sounds kinda like the gtr at work except more laggy, (gtr at work only has a t88 on it)
Must be heard with proper speakers or headphones.
T88-34D or 38GK?
Im assuming 34D or is there another t88?
yer pretty sure its a t88-34d, makes some huge power figure, the nsw guys might know, its a pearly purpleish colour gtr 33 number plates BUS73D. guys name is sam.
Edited by lilcrash
Not much luck selling it then?
http://www.skylinesaustralia.com/forums/index.php?app=forums&module=post&section=post&do=reply_post&f=8&t=371622&qpid=5948582
Yeah, i guess its the same as antilag.
With the 2 step you use a clutch switch and when the switch is activated the ECU retards timing and adds fuel. The more you retard and add the larger the bang so more boost. The last setup that MAztech did was making 20psi and f**k me the noise was unbelievable. Its not going to be as harsh this time around. We only want about 5-7psi at first to see how it gets off the line :D With any luck the tyres will hold up to 15psi :D
i believe i posted two youtube videos that didnt want to be played as embedded videos
here they are
2.6L RB25DET Onevia Drifter
1200HP Series 3 R33 GTR with full TOP SECRET Bodykit in Brisbane
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
    • I'd want at least $40K for mine, but thats easy to say cos I'm not selling anyway.
    • That's incorrect. We have 4 seasons, consisting of pre winter, winter, post winter and a small glimpse of hope!
