okay well Ive been lurking round this forum for a fair while but rarely have much to contribute. My 180sx build is getting near the business end and will soon be attending a lot more track days so thought Id make myself known in case I bump into you in the paddock sometime.
Ive had my 180sx for a few years now, bought it in 2006 in pretty stock form and just tinkered with it in the shed while it was my daily. As is often the case, it pretty soon got to the stage where it tipped over the line of being a suitable daily so I bought a C34 aswell which meant I could get a bit more serious with the 180sx. Ive tried a fair few different types of amateur motorsport including dirt rally, motorkhana, drag, drift and sprints and am pretty much hooked on timed circuit work so thats where the 180sx being built for now. I dont really have a class in mind as I dont have the time to commit to a series, just the occassional club day and sprint events.
Up until recently its mostly been built in the back yard, here's a few pics ofthe progress Ive made so far...
ENGINE
S13 SR20DET
ENGINE IMPROVEMENTS
new oil and water pumps
machined timing case
machined crank journals
decked block
shaved head
balanced crank and clutch
KING bearings
JE pistons
TOMEI rods
1.2mm metal head gasket
GREDDY valve springs
ARP rod bolts and head studs
NISSAN nitrided valves and guides
cold start and idle control solanoids removed from under inlet manifold
coolant lines romoved from intake manifold
KOYO 53mm twin core N-flow radiator
FORD mondeo twin 12" thermo fans
TRIDON thermo temp switch
BILLION radiator hoses
Custom alloy coolant resevoir
Custom alloy air seperator
NISMO radiator cap
NISMO thermostat
NISMO oil cap
NISMO engine mounts - modified
GREDDY underdrive pulleys (water pump and alternator)
BLITZ LM filter
Custom alloy inlet pipe
GREDDY T518Z 8cm turbo kit
BLITZ LM intercooler flipped with custom alloy piping and T Bolt clamps
TOMEI 256deg/11.5mm poncams
TOMEI rocker arm stoppers
SPLITFIRE coil packs
GREDDY winged and baffled sump
shaved rocker cover with -12 breathers
custom oil catch can
setrab 25 row oil cooler with remote mounted filter and billet oil block
Tuned legth steampipe exhaust manifold with ceramic coating
XFORCE dump pipe
RSR 3" front pipe
KAKIMOTO 3" cat back
METALCAT cat - gutted
Magnafuel quickstar EFI regulator boost
Fuel Cell RCI 45L
Bosch Fuel pump 200 l/h
Carter lift Pump
surge tank
custom MoTeC engine loom with plug into fire wall
aircon removed
power steering removed
INTERIER
MoTeC M84 ECU
Race Technologies DASH2 stack dash
Race Technologies DL1 Data logger
BLITZ spec R SBC
BRIDE ZETA III driver and passenger seats
custom fixed seat rails with modified floor pan
TAKATA 4pt Harness
Fire extinguisher hand held
MQ 4L mechanical fire bomb
complete strip except for dash shell
100% custom wiring loom using MoTeC wires, Deutch plugs and water proof switches
dry cell battery relocated to back seat
NARDI sports type rally suede steering wheel
WORKS BELL rapfix II quick release
WORKS BELL short boss kit
body
stock type x kit
SUPERMADE headlight moulds
bonnet held with aero catches
poly carbonate side windows
poly carbonate rear windscreen
front bar dzus clipped on
boot floor cut out and replaced with sheet metal
aluminium rear undertray
custom front tubs
custom tube frame front end - everything forward of the struts
full weld in cage
DRIVELINE
Z32 5 speed
Machined bell housing with adapter plate
semi solid gearbox mount
custom cross member
Short shifter
OS GIKEN STR twin plate clutch with light weight flywheel
custom single piece tail shaft
custom tail shaft loop
CUSCO 1.5way diff
BRAKES AND SUSPENSION
5 stud conversion
ABS removed
Willwood pedal box
Willwood master cylinders
Willwood rear bias adjuster
PROJECT MU braided lines - F
PROJECT MU 6 piston calipers - F
PROJECT MU 355mm 2 piece rotors - F
PROJECT MU HC+ pads - F
Skyline 2 piston calipers - R
310mm slotted rotors - R
PROJECT MU HC+ pads - R
WHITELINE adjustable 27mm front sway bar
WHITELINE adjustable 22mm rear sway bar
GREDDY type S coilovers
ZENITH TUNING steering column spacer
ZENITH TUNING solid rear cradle bushes
D PROJECT tie rods
D PROJECT rose jointed tie rod ends
D PROJECT rose jointed caster rods
D PROJECT lower arm brace
D PROJECT semi solid steering rack bushes
D PROJECT rose jointed rear camber arms
WHEELS
ADVAN RS (silver) 17x9.5 +15 front and 18x10+25 rear
RAYS Gramlights 57d luminous orange 17x9+12 front & Rear
RAYS blue lock nuts
this is what it looked like when I picked it up in 2006. After 6 months of searching it was the cleanest one I could find. It was in immaculate condition with 60,000km so I drove from melbourne to sydney to pick it up.
post-57747-0-08695200-1311236403_thumb.jpg post-57747-0-28728500-1311236449_thumb.jpg
post-57747-0-76766600-1311236601_thumb.jpg post-57747-0-17079700-1311236659_thumb.jpg
Had it for 2 days before I started pulling it apart and the modding began. started off with the just basic stuff like R32 front brakes, few suspension parts, intercoolet, boost controller, turbo, power fc ect
post-57747-0-90714200-1311236724_thumb.jpg post-57747-0-43838300-1311236890_thumb.jpg
post-57747-0-78803400-1311236918_thumb.jpg post-57747-0-92676900-1311236997_thumb.jpg
post-57747-0-76676400-1311237134_thumb.jpg post-57747-0-62163100-1311237184_thumb.jpg
So kept it like that for a little while, was using an old nismo clutch at the time which I had left over from a previous project but it got a bit tired so in went a twin plate from OS Giken
post-57747-0-45864400-1311237251_thumb.jpg post-57747-0-48358900-1311237345_thumb.jpg
With that worn in and a freshly tuned 219kw, I went to heathcoat drags for a bit of fun and mananged a few 12.6 sec @119mph before all the teeth off 3rd gear sheared off. Using this as an excuse to upgrade, I bought a conversion kit for a Z32 box and bolted it up.
post-57747-0-82634900-1311237395_thumb.jpg post-57747-0-34981900-1311237536_thumb.jpg
https://www.sau.com.au/forums/topic/371664-180sx-circuit-car/
after a handful of drift days at winton and calder park, the motor dropped compression so it was out with the old and in with a new one.
post-57747-0-41726000-1311338239_thumb.jpg post-57747-0-72129700-1311338311_thumb.jpg post-57747-0-22074500-1311338353_thumb.jpg post-57747-0-21394200-1311338509_thumb.jpg post-57747-0-34630600-1311338708_thumb.jpg
Almost immediately after it was run in and retuned, I drove it to brisbane where I now live. car pretty much stayed in one piece for the better part of a year which was cool because previously I think the longest it stayed in one piece was 2 weeks. a few little things changed here and there but nothing major. This really allowed me to get used to driving it hard and I racked up about 20000km of hills and track driving. At this stage I was still very much into drift so only ever hit up QR.
post-57747-0-96557700-1311339176_thumb.jpg post-57747-0-43755500-1311339221_thumb.jpg
After a fair bit of drifting I got a bit over it and bought a stagea so I could make the car a bit more track focused. first up was an interier and air con strip. the more trim I pulled out the more wires I found for useless things like interier lights and such as I went I stripped back the looms and tidied it all up.
post-57747-0-70065900-1311339303_thumb.jpg post-57747-0-04597600-1311339372_thumb.jpgpost-57747-0-68583400-1311339483_thumb.jpg post-57747-0-64369300-1311339451_thumb.jpg post-57747-0-25015000-1311339518_thumb.jpg
after that the next big change was a swap to five stud to get some wider wheels and bigger brakes. Went with CSC 343mm rotors, big 4 piston calipers and ADVAN RS wheels. with this came flared gaurds and a few height adjustments to get it right.
post-57747-0-20571100-1311339568_thumb.jpg post-57747-0-47731900-1311339613_thumb.jpg post-57747-0-66878800-1311339643_thumb.jpg
After this things started to get a bit more serious again so I drove thecar back to melbourne and dropped it off at Meridian Motorsport to get a full cage and a few other bits and pieces. I could have got it done in brisbane for cheaper but after a lot of research I decided Meridian did excellent work so went with them. After taken a fair chunk out of my wallet I had it back in my shed ready to get cracking with some more work.
post-57747-0-85903600-1311339822_thumb.jpg post-57747-0-66364000-1311339907_thumb.jpg post-57747-0-04330400-1311339969_thumb.jpg
post-57747-0-83546700-1311340002_thumb.jpg post-57747-0-17067500-1311340044_thumb.jpg post-57747-0-46191100-1311340144_thumb.jpg
Was the first time I had tried painting anything and with a borrowed paint gun it came out alright. Its not perfect by any means but hey it only cost me $150 in materials and was worth it for the experience. I didnt paint the engine bay at this stage because I was planning on doing a bit more work in the engine bay.
post-57747-0-05550600-1311340184_thumb.jpg post-57747-0-78637300-1311340518_thumb.jpg post-57747-0-92709500-1311340543_thumb.jpg
Edited by boost_bus180
so after the paint dried I thought Id tidy up the looms a bit more but I got confused by it all and thought itd just be simpler to rip it all out and start again. before this the most complicated wirign job Id done was a tow bar plug so kinda jumped in the deep end. learnt a lot though
post-57747-0-08622400-1311404508_thumb.jpg post-57747-0-80606700-1311404603_thumb.jpg
About this time I changed a few other things like a nardi steering wheel with WB boss and quick release. Wasnt at all looking for a new brake setup but a new set of Project Mu gear came up cheap so I impulse bought it. took the CSCs off and put them on my stagea. Stagea already had 32GTR brakes so now Ive gotta find something to put them on. was amazed the 17s fitted over the brakes but glad they did because I wasnt ready to buy new wheels.
post-57747-0-73222000-1311404955_thumb.jpg post-57747-0-15495700-1311405128_thumb.jpg post-57747-0-33652000-1311405188_thumb.jpg post-57747-0-25162100-1311405245_thumb.jpg
I tried a few different gauge setups with the stock cluster, defi gauges and then apexi gauges. I was never very happy with the wiring in it as the more I learnt themore I wanted to start over and make it better. I persisted with it though cos it was taking me forever and I just wanted to drive it. Once I was finished wiring it up I went to start it up but managed to wire up the ECU wrong and set fire to the power fc. not cool!
post-57747-0-69497500-1311404659_thumb.jpg post-57747-0-43854500-1311404759_thumb.jpg post-57747-0-05809000-1311404861_thumb.jpg post-57747-0-60728500-1311405053_thumb.jpg post-57747-0-58552600-1311405441_thumb.jpg
So fed up with it all, I ripped it all out again and cleaned it up ready to give to someone else. At this point I was pretty much addicted to taking weightout of the car so I ditched the powersteering, converted therack to manual and bought some supermade headlight moulds. Also got a thing made up to replace the water hoses that run under the inlet manifold as its just a mess under there with cold start and turbo lines and heater box crap so it all got binned. much nicer now Also got my rocker cover shaved, sand blasted and powder coated with some -12 fittings on top for the new catch can setup
post-57747-0-86027700-1311405484_thumb.jpg post-57747-0-18492300-1311405304_thumb.jpg post-57747-0-06527600-1311405562_thumb.jpg
post-57747-0-38868900-1311405641_thumb.jpg post-57747-0-54443100-1311405694_thumb.jpg post-57747-0-49367700-1311405732_thumb.jpg
After that I loaded it up and dropped it back off to meridian so they could start giving it a fair birthday. Im not a fan of letting other people work on my cars but they're great to deal with and do excellent work so I dont mind.
I was never planning on getting all of this done at once but I was in a position where I couldnt touch the car for a good 8 months so figured Id get a few years worth of mods done in one hit, that way I can finally get it out of the shed and just enjoy it without devoted all my holidays for the next 2 years to swinging spanners in the shed.
so once there, the guys got stuck into rewiring it completely with all new engine loom, all new sensors. theres a lot of little bits and pieces throughout that theyve done but that list could go forever so I wont bother trying to list them all. boot floor got cut out so a new fuel setup could go in. standard tank was 60ltrs and this one is about 45ltrs but I think that'll do me fine, its just a little 4 cyl after all
post-57747-0-18629400-1311406686_thumb.jpg post-57747-0-22346700-1311406740_thumb.jpg post-57747-0-24232900-1311406798_thumb.jpg
As I fried my old ECU, it gave me the opportunity to upgrade to a MoTeC and a new dash setup. On previous track days Ive seen a few cars catch fire and even had a close call myself when my first motor popped and spewed all all over the turbo so felt it would be a wise idea to get a fire bomb for that piece of mind.
post-57747-0-67944300-1311406862_thumb.jpg post-57747-0-09491400-1311406907_thumb.jpg post-57747-0-14166800-1311406944_thumb.jpg
post-57747-0-16350400-1311407044_thumb.jpg post-57747-0-34622900-1311407124_thumb.jpg
things in the engine bay started to get a bit of attention too, the front end got cut off to make way for some tubs and a new radiator support. Although the last one wasnt damaged, I hate wheel scrub and wanted the front end beefed up a bit so it wont cave in if I bump into something.
post-57747-0-30426800-1311407181_thumb.jpg post-57747-0-24498500-1311407218_thumb.jpg post-57747-0-12923600-1311407261_thumb.jpg
got a bunch of fidly things done that were needed too. new catch can, oil cooler, pedal box, intercooler piping, new gearbox cross member and a swag of other stuff that needed to be sorted.
post-57747-0-84378200-1311407346_thumb.jpg post-57747-0-02964700-1311407388_thumb.jpg post-57747-0-43296000-1311407431_thumb.jpg
post-57747-0-39765000-1311407477_thumb.jpg post-57747-0-34528100-1311407515_thumb.jpg
thats about where Im up to at the moment, will keep the pics coming when there's more to show
Top stuff mate. Have some very good gear in it. Should perform really well.
Have you done any track days in it yet?
hey mate, thanks. I've done 2 drag days, a handful of drift days and only 1 circuit day at winton which wasnt timed. that was way back in the day when I first got it though. should hopefully be hitting up the victorian tracks a bit more toward the end of this year
  • 3 weeks later...
absolutely BEAUTIFUL car mate. lovely work gone into it both by yourself and meridian too. it's cool learning as you go. and you do learn bloody heaps. it's going to be so much fun when you finally get it on a track. :)
awesome build mate!!
Those project Mus are porn!!!
Saving for a set myself!!!
yeah they're massive overkill for my application but they were so cheap that I felt I would be ripping myself off if I didnt buy them. Can you believe they were only $3K? RRP is close to $6K!!!
wow 12.6 with 219kw is a great effort. love this car.
thanks mate, my fastest was 126mph but was a tad slower at 12.7. will definately go back for another go once the car is back in one piece and see what difference it's made, if any.
Awesome build mate, going all out! Particularly like the fuel system set-up - have drawn up something similar for my old rig.
thanks mate, yeah Im pretty happy with it.
Thanks I really appreciate that Baron. Its worth it just for the experience for sure, at the start I knew stuff all so its good to see how far its come. And your right about the track time, has been over 2 years since it last got driven in anger.
  • 3 years later...
  • 2 years later...
Holy shit its been a long time since I updated this thread!! Car has come a long way since mid-2011, thats for sure!
I continued building the car up until early-2013. It managed to see a bit of track time - just enough to iron out most of the bugs that are associated with an overhaul of this scale.
At a shakedown testing day at Winton Raceway, the car was just starting to feel good and then the gearbox decided it'd had enough. A few laps later and the motor followed suit.
I had been through a fair bit of heartache getting the car to that point and was so depressed with it that I took it home and locked it away in storage till I could be bothered with it again. Figured it wouldn't be too long before I got over it and had it going again.
Fast forward nearly 4 years to now....motivation has finally returned and the car is about to come of hiding for a full overhaul. In case there are some folks here interested in seeing what happened in the last few years of development before it was tucked away, I'll fill in the last few years with a few catchup posts. Once caught up, I'll endeavor to keep this thread updated with the new bits.
  • Like 1
So, rewind to 2011....
I had been shopping around for a rear wing for a long time but couldn't find anything local at the time. Im a big fan of supporting local brands when I can, but back in 2011 there wasn't much around. This 1580mm wing is molded from a V8 Supercar wing, and is rock solid - can push/pull the car from it and not have to worry about it breaking. A sub-frame was made beneath the hatch which meant I didn't have to worry about downforce not making it to the chassis. A lexan rear windscreen was made up and screwed into place too. The mounting holes for the stock spoiler were all welded up and painted over. to look like new.
My aim with the wiring was always to make it as simplified as possible, so a full new loom was made using only top quality components. The cold start idle and every other electrical nice-to-have was deleted from the engine bay. A bulkhead plug was used at the firewall to make engine removal an easy affair. Once the wiring was complete, the engine bay was stripped to get busy on the remaining fabrication.
Still needed to finish off a tonne of fabrication on the new front end. The new tubs were welded into place and finished off and I was really happy with the outcome. No more scrubbing big tyres :) I always wanted a removable radiator support bar to assist in engine removals, so some tube was bent up and located by slotting into two sleeves welded to the chassis rail ends. The tube is then secured by a bolt screwed up from the bottom of each sleeve into a captive nut, which makes it very solid. Tabs were welded on to mount the headlight molds, front bar, radiator and intercooler.
A decision was made to extend the strut brace to the front bumper to add some much needed strength and rigidity to the front end so that i could hang a splitter off it and also so the front end could take a light shunt without caving in completely. After that was done, the engine bay was ready for a lick of paint and final assembly could get underway.
With the engine back in place, it was easy to start bolting all of the other components back into their spot. Radiator along with my trusty old thermo fan setup from a Ford Mondeo was bolted into place. I have often thought about upgrading these fans as they're not a perfect fit and there are better options out there, but they work well enough for now. Some new Billion radiator hoses and clamps too. The radiator is a Koyo N-flow design which makes the coolant flow three times through the air stream. Im still not convinced this is a great design but I've got it and it works. In my previous setup, the thermos were controlled by a temp switch fitted next to the top hose; however, that is now redundant as the MoTeC will take control of those duties now. A new hose fitting was also welded to the top hose to help bleed the system.
Whilst the engine bay was getting put back together, few loose ends were being tidied up on the inside too. The fire bomb mounted on the floor behind the passenger seat was plumbed in. One nozzle is under the back of the car pointed at the fuel pumps, 1 under the dash pointing up at the driver and then one on each of the front strut towers pointing at the fuel rail and the turbo.  Firebomb can be activated by pulling the red lever next to the drivers seat or there is a second one fitted at the base of the windscreen. Hopefully never have to use this system, but if that worst case scenario eventuates then I can hopefully save it from burning to the ground.
Pedal box was next to on the list. Decided to go with the simple design of the Wilwood hanging style as it didn't require cutting into the floor or firewall to fit. Note after these photos a few more clamps were used under the dash to tidy the hoses up. Came up so neat that it would have been a shame to retain the old standard brake lines that were looking well used and out of place in the new engine bay, so some new braided lines were plumbed in. Also had a new clutch line made up which fits much better than the old junk standard setup which actually made the clutch line the lowest part of the car just begging to be ripped off by a ripple strip. Fluid reservoirs were positioned in the engine bay in front of the driver and as far away from heat as possible.
While new brake master cylinders were being decided on, I opted to upgrade the rear brakes from the standard S13 calipers and S14 rotors, to a set off an R32.
I didn't worry about rebuilding these or getting new rotors and better pads as I figured that can come later. R32 isn't a huge upgrade, but they should be a much
better match for the big fronts and it should be pretty evident at the next track day whether or not they need to be bigger. At $100 the price was right anyhow.
  • Like 2
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
