Coming home from work this arvo, cruising on highway and car stalls, WTF
Tried restart, got dash lights, cranks, no PFC handset display, no fuel pump, checked all fuses - nothing
Checked PFC in another R33 - nothing, tried std ecu in mine and all ok except I got 750cc, gt3076r, z32 afm.
So does anyone repair or test power fc?
Can I check with nissan consult?
p.s. Anyone got std R33gtst injectors I can borrow?
https://www.sau.com.au/forums/topic/371844-power-fc-died-r33-rb25det/
there are places that repair them
you can also get apexi to repair it via nengun.com for official repair
you cant check it with consult so dont bother trying
open the powerfc up and look for any burnt tracks or damage, also smell for any burns
Bit off topic but I was just wondering, if I gave my tune from my PFC to someone that remaps stock ecus could they put my PFC tune onto a stock ecu??
It can be done but you need a nistune in your 33. That will cost about 700. Get your pfc quoted for repairs and go from there. your tuner should have your tune file.
^^ no each ecu code is unique therefore incompatible.
To OP the pfc seems to have lost the input resistor, i can do it for $80, but im sure you could get it done for far less locally.
provided they dont replace the main memory chip you shouldnt loose the tune.
i think thats the only thing no longer available... got two perfect pfc's... but the main "chips" are no good :(
seriously its a easy job to fix. far easier than replacing your injectors.
I don't think I filled my post enough but what I meant was the tuner can load up the Power FC tune, and mimic the data across to the Nistune ECU. You tuned tao's car I believe, he has given me screen dumps of his timing and ignition maps to provide my tuner. Even though tao runs a Nistune, the tuner was still able to get an idea of how things were running and how to setup the tune.
that was sort of what I was thinking, I believe Toshi does remaps to order, as in send him your specs and ecu and he sends it back tuned..
Which I would think is a less than perfect way to tune a car but..Surely if you gave him your previous tune data he could read it and mimic it so the tune should be close to spot on..
yeah as I said it would be a less than ideal way to do it..but say for instance you had a blown PFC and couldnt afford a new one..but you have your tune on file an old ecu laying around and remaps are only a few hundred bucks, it could just be enough to get you going again..
What is the chip? I work in micro processor development and might be able to find an alternative that uses the same protocol and mapping for the memory.
edit: Or are you talking about the micro itself? not the memory?
Edited by Rolls
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
