  • Replies 71
Hi Guys.
I'm running a Skyline Group Buy right now, if anyone who missed out but would like to get involved; http://www.skylinesaustralia.com/forums/topic/376917-whiteline-sway-bar-group-buy-r32-r33-r34-gtr-and-2wd/
As an aside; the rear Whiteline bar is 1075mm wide at the links. Hopefully this will help anyone who is unsure of the size difference when fitting to an Auto Subframe.
If one of you would like to measure your Auto Sway Bar and post the measurement that might help too.
Cheers, Dale.
  • 1 year later...
Here you go rob. http://www.skylinesaustralia.com/forums/topic/423821-whiteline-rear-sway-bar-link-crooked/#entry6889440
It fits fine and has held up to some hard cornering etc. had a look last week and it shows no sign of slipping or moving
I got the BNR11XXZ24mm for my rear (on a S1 auto awd) and I didn't modify anything. I'll try to remember to have a look in the morning to see if the links are at an extreme angle but I don't think so
The Whiteline bar is 50mm narrower than the one on the auto, which does push the links out quite a long way.
I don't like the angle using the links that Whiteline supply with the bar, but using their H/D ball links, it is perfectly safe.
They have far more articulation, and are much stronger.
Had a quick look at mine today (sorry no time to jack up and measure - maybe later in the week) and they are at an angle but not alarmingly so and have been like that for about 4 years. Still the HD links look good - how much for a pair Dale?
Pm sent.
  • 1 month later...
Hi there i have an s2 stagea rs so 2wd… apparently thay come with no sway bar on the rear just wondering if you know what bar i can use ive herd RS have s15 gear but been told an rs4 bar will fit… any knowledge will help cheers
The rs4 bar fits, but you need to add some spacers to straighten up the links, approx 15mm a side, and slot the u brackets a little bit due to the wider cradle. You need longer bolts when you add the spacers, I think some guys leave the links on the angle but it's easy to fix.
And it's the best thing you can do to the handling of the car, huge difference! just need to also get the u brackets, and bolts, from another car, that's not part of the kit but holes are already on the car.
or just get an r33 gtr or s15 rear bar
get the fattest whiteline bar you can
NISSAN 200SX S14, S15(7/94-02)
NISSAN 240SX S13, S14(1989-98)
NISSAN SILVIA S14, S15(7/94-02)
NISSAN SKYLINE R33 GTS, GTS-T RWD(1/93-12/98)
NISSAN SKYLINE R33 GTR AWD(1/93-12/98)
NISSAN SKYLINE R34 GTS, GTS-T RWD(11/98-02)
NISSAN SKYLINE R34 GTR AWD(11/98-02)
NISSAN STAGEA WC34 RWD/AWD(1996-9/01)
bnr11xxz for reference fits all the above
Yep, but what I am saying is you still need the spacers to align the links on an rs. I know cos I have one. As per my previous post (sorry about formatting, mobile editor is a dud) the s15 and gtr bar is the same. No way out of it, spacers required.
If you are using the stock Whiteline links; it's definitely a good idea; but if you go to the H/D Whiteline links, the misalignment is well within their ability to cope.
And even then; they have enough thread length to accommodate a spacer on the bottom end.
I had read that somewhere, but couldn't justify the price for a street car, vs some spacers and bolts that cost me nothing.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
