So my car has been in a minor accident front guard, Bumper, have been replaced i have also took it to a guy and i have decided to do the full paint job windows out + repair etc (G & S Bodyworks Yennora) his name is Gus. Has quoted around the 4k mark for a full cut down window out re-spray.. plus repaairing the damage. THis includes the after market seals front and back.
How is the price? A i getting ripped?he seems to tell me his actually doing a good pric for me and normally it would be over the 5 k mark
depends how much damage but yes that sounds like a good price.. depends on the quality of the job getting done to though..
Too many variables and missing details to say definately..
Do you mean a FULL respray of your WHOLE car with windows out?
If it is, plus repairs, 4k seems reasonable.
A good&cheap full respray with windows out nowadays is worth like 3-3.5k
A full respray should cost more than that alone.
I am pretty fussy but i would baulk at a full paint job and repairs for $4k. Myself i would be expecting closer to $10k for a quality job. But thats just me, i dont like decent work, i like it to be top quality
If Peter at Bodyform uses them they must be decent, though i thought Peter did all the work himself usually? Or does he just use these guys for paint?
  • 4 weeks later...
Sounds like a very decent price, very cheap for a window out job with repairs.
A half decent window out job will easily be over 5k at most places, it all depends on how they get the car and what work is required, a car pre prepped will cost a lot less.
The places where you see full resprays for like 3k arnt window out jobs, I work in the 'trade' and I have seen some poor paint jobs and great paint jobs and 3k wont get you much especially if you have repairs. It helps if you know someone as most shops will try to rip you off if your just a random.
I would research this place or see some of his work and make sure he knows that if there is something not done right he has to fix it.
Mine has just gone undergone a full respray windows out, every dent scratch all new seals front lip repaired etc etc
That has just cost me $9k :)
You gets what you pays for though!!
I hate runs in paint or in-perfections etc I could of gone cheaper but at what cost...
So yeah $4k sounds good lets just hope its a good finish...
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
