Hey guys, My names Racqel.
I am looking for someone to kindly let me use their car (they can obviously drive it) for my formal, which is in November (2011).
It will be driven around the Wollongong area, to the photos, then to the formal, that is all.
I am willing to pay 100-200 dollars, for an hour.
I am looking for a clean silver GTR (R35)
or a 34 gtr.... if it's nice enough :P
please get back to me ASAP!
"I am willing to pay 100-200 for an hour"
Is the above said paragraph separate from the rest of the thread? If so, may we gentlemen relay what other services 'er extras we can offer for that price and within that time frame?
Ok, here's a constructive comment for a change;
There's very little R35's around in the entire country, then again the section of those that is silver is smaller again. So the chances are pretty small.
On top of that, the chances are that if one was available and in Silver, they'd live in Sydney. So out of the $200 on offer, they'd be making $150 after expenses...
....but the biggest issue? Someone with an R35, which is worth over 100k, probably has plans that dont involve formal runs.
Sorry to be blunt.
You're better off to find a nice R34 GTR (and there's certainly a few of them on here) and make the offer to the owner. If you find one with a big exhaust and cams it will sound downright angry and lets face it, you want it to stand out in the crowd and have a better car than your friends - the sound of a tuned RB26 at idle with cams will sound so much better than the usual formal cars like H2 hummers, S class Merc's etc, believe me that will grab attention.
Here's something I took my mates sister in to her formal a few years ago, this thing sounds great and there wasn't a single person in that line not looking at it. Sounded a million times better than the other cars there on the day;
End of the day, you'll have better luck finding an R34 GTR. Good luck with it.
Too good Terry.. too good :rofl2: :rofl2:
beer boss- im sure there must be a few 35's willing to do it.
i fellow forum member was going to drop me off to the formal last year. but group of lads + pre drinks, i thought maybe next time lol
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
