Did back to back dyno testing at Boostworx. Eflex made less power then normal 98. The liberty e85 made 15-20kw more. Eflex isn't e85 its e70-e85 as it says on the pump.
While I dont doubt your figures this is totally the opposite of the testing I have carried out for our own vehicles.
However I have never tested 'Liberty' E85 only the United CSR Sarina manufactured blend, I think you may be getting confused with United. If there is a Liberty selling here let me know and I will test it.
E-Flex is a much maligned fuel. As stated on the brochure on the Caltex servo counter this fuel WILL contain as little as E70 in some circumstances, and yes it has when I test it (71% concentration is the lowest measured directly). This gives the fuel an effective tuning RON (my calcs here, not measuring on an octane machine) of around 110 - 112 RON. It is also highly oxygenated which means that it is capable of delivering good combustion energy - significantly higher than that of E85. I do not know why Boostworx have found it makes less power than 98 octane fuel as on a typical 200rwkw turbocharged engine (on a Mainline dyno) we can normally extract in the order of 10% - 14% additional power and torque swapping from 98 to E-Flex. The tuning technique required does however require some thinking outside of the square with some engines.
Yes, my family hack is a Flex-Fuel setup EVO X, and yes it runs on either 98, or more preferably (as it makes a ton more power and costs $40 a week to run) E-Flex :)
CSR Sarina E85 is a little more pure for the racers measuring at around 88% Ethanol in most cases and can make a tad more power than E-Flex (not a great deal in it). We run the United CSR blend in - all - our Willall Racing track and drag cars, but maybe we are missing something? :pirate:
https://www.sau.com.au/forums/topic/372229-e85-fuel/#findComment-5936774
Yup, I meant United not liberty on Tapleys Hill Rd >_<
Not to sure whay exactly it made less power then 98, wasn't by much though 230rwkw vs 226rwkw. Could have been a bad batch of fuel or it could have been down to tuning technique.
But as I said, and you stated above. The United E85 will make more power then eflex as its a more pure blend. Considering the United E85 is as cheap as eflex I know what i'll be buying all day every day.
https://www.sau.com.au/forums/topic/372229-e85-fuel/#findComment-5937061
Cheers guys.
Considering runnoing the evo on it.
A few blokes from other states have been doing it for awhile.
Have seen back to back dyno results and have been impressed...
As far as 'stuffing things up' i havent heard of much. what are the risks?
https://www.sau.com.au/forums/topic/372229-e85-fuel/#findComment-5937191
Here, here, good to see your still a champion for the good stuff Mr Donnon.
I say go for it, Eflex is more than capable even at 70%.
I use the United E85, but have no problems at all throwing in Eflex,
United's wins on my seat of the paints dyno.
Recently tuned a S15 SR to 1.85bar on E85 running a disco with all the bolt on's, got a good compromise mapping both fuels, hasnt had it's power measured yet, but far out it fly's, high 200's at a guess.
https://www.sau.com.au/forums/topic/372229-e85-fuel/#findComment-5937549
.82 rear or .64? I've got the .64 making 240rwkw at 20psi dropping off to 16psi (small wastegate). If you have .82 is there much lag? would be keen to see power graphs as thinking of changing rear housings on mine.
https://www.sau.com.au/forums/topic/372229-e85-fuel/#findComment-5937604
I'm amazed at the attitude towards E70 vs E85............I think peeps are forgetting that the fuel alone won't give you the kind of power you're looking for.
In fact, 98 pump fuel will burn much better (combust) than the higher octane Ethanol.........the stuff just doesn't burn!!!
What the Ethanol allows you to do is turn up the boost and and throw more ignition timing at it, hence where the additional power comes from................the stuff doesn't know the meaning of the word Detonation!!!
https://www.sau.com.au/forums/topic/372229-e85-fuel/#findComment-5938071
people still hate on e85 haha, i have been running e85 for 3 years thanks to adrian, never had a issue pushing awesome power! it really is power for nothing compared to what some people spend chasing small gains, as well as safer. as for blends tryed nearly all varietys and never had issues.
https://www.sau.com.au/forums/topic/372229-e85-fuel/#findComment-5938162
    • Order for the 2025 model R35 GT-R were accepted from 3rd March and 26th August the last order rolled off the production line at the Tochigi plant. Concerning the R35 GT-R replacement, current Nissan CEO Ivan Espinosa said "Nothing has been decided about the GT-R at this time, but we are well aware that everyone is waiting. The GT-R will evolve and reappear in the future. Please be patient until that day comes." Nissan has a lot of issues with management and finances so take Espinosa's words with a big grain of salt. From what discussions I've had and read about here in Japan, not a lot of people are confident about Nissan's future, let alone the next GT-R.
    • Thanks. We getting some parts along too so he will be solving the speed issue like next week so i will let you know what he came up with.
    • 21 is explicitly the coils detected as the issue. Is it guaranteed the actual issue? No. Just the ECU thinks it is. When you say rattling, describe it better, get an audio clip as best you can if possible.
    • Yea got me coppers. Bad news is I just put them in and the car still has the light and shakes. I also noticed I hear like rattling coming from the exhaust piping right under me. Does 21 also have a possibility of being O2 sensors?   So, coil packs are good, the harness is good, the MAF is working, and obviously the spark plugs just replaced and working.
    • Make sure you drop the GTT base tune back in, and set your injectors again, this will remove anything playing up with it you may have removed. Possibly lean there as it's normally a fast transient going THROUGH atmospheric pressure, and a turbo motor would then quickly go richer as boost builds. The only worry you MIGHT have is ignition timing, as the DE is higher compression than the DET from memory. But again, you're not in boost, so the DE motor will be a lot more forgiving at atmospheric.   Get Murray, Kinkstahs, and Johnny's input on tuning haltechs, those guys have played with tuning enough in the past to be able to help now you're past the trouble shooting stage of the MAP issue
