Did back to back dyno testing at Boostworx. Eflex made less power then normal 98. The liberty e85 made 15-20kw more. Eflex isn't e85 its e70-e85 as it says on the pump.
While I dont doubt your figures this is totally the opposite of the testing I have carried out for our own vehicles.
However I have never tested 'Liberty' E85 only the United CSR Sarina manufactured blend, I think you may be getting confused with United. If there is a Liberty selling here let me know and I will test it.
E-Flex is a much maligned fuel. As stated on the brochure on the Caltex servo counter this fuel WILL contain as little as E70 in some circumstances, and yes it has when I test it (71% concentration is the lowest measured directly). This gives the fuel an effective tuning RON (my calcs here, not measuring on an octane machine) of around 110 - 112 RON. It is also highly oxygenated which means that it is capable of delivering good combustion energy - significantly higher than that of E85. I do not know why Boostworx have found it makes less power than 98 octane fuel as on a typical 200rwkw turbocharged engine (on a Mainline dyno) we can normally extract in the order of 10% - 14% additional power and torque swapping from 98 to E-Flex. The tuning technique required does however require some thinking outside of the square with some engines.
Yes, my family hack is a Flex-Fuel setup EVO X, and yes it runs on either 98, or more preferably (as it makes a ton more power and costs $40 a week to run) E-Flex :)
CSR Sarina E85 is a little more pure for the racers measuring at around 88% Ethanol in most cases and can make a tad more power than E-Flex (not a great deal in it). We run the United CSR blend in - all - our Willall Racing track and drag cars, but maybe we are missing something? :pirate:
https://www.sau.com.au/forums/topic/372229-e85-fuel/#findComment-5936774
Yup, I meant United not liberty on Tapleys Hill Rd >_<
Not to sure whay exactly it made less power then 98, wasn't by much though 230rwkw vs 226rwkw. Could have been a bad batch of fuel or it could have been down to tuning technique.
But as I said, and you stated above. The United E85 will make more power then eflex as its a more pure blend. Considering the United E85 is as cheap as eflex I know what i'll be buying all day every day.
https://www.sau.com.au/forums/topic/372229-e85-fuel/#findComment-5937061
Cheers guys.
Considering runnoing the evo on it.
A few blokes from other states have been doing it for awhile.
Have seen back to back dyno results and have been impressed...
As far as 'stuffing things up' i havent heard of much. what are the risks?
https://www.sau.com.au/forums/topic/372229-e85-fuel/#findComment-5937191
Here, here, good to see your still a champion for the good stuff Mr Donnon.
I say go for it, Eflex is more than capable even at 70%.
I use the United E85, but have no problems at all throwing in Eflex,
United's wins on my seat of the paints dyno.
Recently tuned a S15 SR to 1.85bar on E85 running a disco with all the bolt on's, got a good compromise mapping both fuels, hasnt had it's power measured yet, but far out it fly's, high 200's at a guess.
https://www.sau.com.au/forums/topic/372229-e85-fuel/#findComment-5937549
.82 rear or .64? I've got the .64 making 240rwkw at 20psi dropping off to 16psi (small wastegate). If you have .82 is there much lag? would be keen to see power graphs as thinking of changing rear housings on mine.
https://www.sau.com.au/forums/topic/372229-e85-fuel/#findComment-5937604
I'm amazed at the attitude towards E70 vs E85............I think peeps are forgetting that the fuel alone won't give you the kind of power you're looking for.
In fact, 98 pump fuel will burn much better (combust) than the higher octane Ethanol.........the stuff just doesn't burn!!!
What the Ethanol allows you to do is turn up the boost and and throw more ignition timing at it, hence where the additional power comes from................the stuff doesn't know the meaning of the word Detonation!!!
https://www.sau.com.au/forums/topic/372229-e85-fuel/#findComment-5938071
people still hate on e85 haha, i have been running e85 for 3 years thanks to adrian, never had a issue pushing awesome power! it really is power for nothing compared to what some people spend chasing small gains, as well as safer. as for blends tryed nearly all varietys and never had issues.
https://www.sau.com.au/forums/topic/372229-e85-fuel/#findComment-5938162
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
