I thought Autech GTRs were NA.
Get a Chaser IMO.
Nah you're thinking of the R32 Autech skyline26. 4 door with no GTR guards,GTR front,N/A RB26DE with automatic gearbox. not sure if it had attessa.
Do what Jash did and build and R34 version, lucky guy who owns it now.
i have seen this GT-4 in the flesh at autosalon and the c-red showroom in welshpool. Jashs "very" varietta was also awesome.
i recently caught up with him at Rising Sunday and he has built a 3.1 stroker stagea ffs. :laugh:
Hehe still a little way off being available at the moment.
If someone wants to do a Mark X test car on the other hand...
Aww I thought they would have been eligible by now what with the feature in HPI a while back and all.
