  • Replies 218
Posted Images
well as far as im aware, most tuners dont intentaly blow up engines. ive had one let go.turns out it was the third second hand piston that was slapped in the engine. (poped 2 times prior and a second hand piston and rings got thrown in...
from what you have said its a slapper with oe strength parts pushing 3x oe power.. you dont really have anyone to blame. was the tuner aware of cast pistons being used? either way. the bolt ons you have are capable of over powering the bottom end..
id be throwing some rods and pistons at it.
did you gap the rings yourself? or did the machine shop do that?
shop did it
yeah he knew they were cast pistons. said hees done heaps around 500-550rwhp. even 600rwhp hees done on one. although im not sure how the mahle pistons compare to standard nissan ones. he said theyd be ok but
Edited by joe blo
I'm not a professional tuner, however I can tune my car the way I want it to run ie: economy off boost and power on boost or if I choose (but I don't) to shoot flames on every downshift. It "should" be a given that someone who tunes cars all day long wouldn't make a mistake like that. I know I wouldn't and I only tune mine and a couple of mates cars. No det here.
Pretty sure both tuners I have been to made me sign a disclaimer before they would tune my car, saying that I understood and accepted there were risks in putting my car on the dyno and they would not be held responsible if anything went wrong.
Joe, you're on an Internet forum, how do you expect us to give you an explanation??
I cant disassemble your engine from here and measure it with a micrometer.
Have you even pulled it yet?
well youve given the diagnosis its all my fault. yous have gotta know what from.
Mate without giving you shit about it I would say read a stack of books about professional engine building and (almost) memorize them and thoroughly understand them. Hey at least it ran right?! So you have a basic foundation of knowledge there. Don't stop learning now, we learn from our own, and others mistakes. It takes years to gain the skills to work on cars properly. I'm 30 and pulled my first stromberg carby apart when I was ten. I'm still learning. I would say, pay to get it built next time and then you'll have the car/engine you that will last too. In the mean time get reading those text books or get a mechanic apprenticeship.
    • Ok so will run the piping over that radiator and no plenum it is. Put that money towards a Haltech and see what suits. Any ideas something like an elite 2000 or 2500 right? My long term goal is 300kw e85 and manual swap and that’s a dream come true. For now will be 200kw and auto the stock rb25det neo intake isn’t too expensive with throttle body. If I was to have the port matching done, Would that be better than the stock de intake as the det has bigger holes plus has the spots for sensors etc? And suit more long term?  appreciate the advice?
    • You understand AFR is not the only thing that contributes to it pinging yeah? Funnily, what the AFR gauge will tell you when it likely is pinging, is going to make you think things are really safe and good.
    • Run the piping how we all have for decades. Also the duel runners with the +T setup dramatically helps it gets on boost quicker. Yes, chase huge power it'll become a problem, but you're a long way off when you're already saying an aftermarket ECU is out of the budget. You also say NisTune as it's simple, and then immediately say it'll be painful, meaning... It won't be simple. It will likely cost you a lot more stuffing around with a Nistune, than just putting a Haltech or similar in.
    • I’ll order an afr gauge to keep an eye on it.  Then will get a haltech soon
    • TD05 or maybe pulsar PSR2867r Gen 2?  id love a garret but it’s quite out the budget for now and I’m not chasing crazy power.    yeh fuel pump haven’t looked into but whatever works, kind of last on my list.    Nistune because it’s simple but Ik it’s a lot of pain especially as I’m auto +t with the whole seperate TCM etc still investigating that. Haltech id love but once budget tight for now atleast.    finally the reason I’m trying for a plenum instead of the stock intake is I already have a standard Intercooler mounted etc. so the ports are on both sides so trying to not have to go over the clutch fan radiator etc. trying to find a good deal return flow if I don’t than this will do for now I guess. btw any ideas with that, apparently some people have to cut blades to reduce it from hitting the Intercooler piping over the radiator ? Thanks
