A friend of ours had an mspec front bar, then swapped it for a 400R front bar, then wanted my mspec bar because he hated the 400R.
I personally don't like the look of a skyline with just a 400R front bar. The bar is lower than the rest of the car and looks yucky.
My 2 cents
400R bar is awesome it was designed by Nismo Specifically for the R33
I love mine, although i have a new one now.. 400r again :D
You need to have sideskirts with it otherwise it does look too chunky on the front
If its mounted properly its not TOO low, however you do need to be carefull on just about every driveway
It is lower than most, but thats what comes with the bar and its looks :)
The GTR style bar on my GTST is about 140mm from the ground. Its not too bad as long as you are careful. I crunched it pretty bad a few months ago but that had nothing to do with the height. Opps!
The Stock GTR is currently 200mm off the ground. Have to do something about that!
Yeah, mines pretty low too.
Just beware of underground or multi story carparks.
At least with an evil speed bump you can back up and go over at an angle or even turn around.
Not so in a carpark thats only one lane wide, with 10 cars stuck up your ass.
Oh and avoid that dirt carpark behind the Regatta. it has potholes that'll tear your bonnet off!
hahaha, yeah i found out about the reggatta car park the hard way.
My front bar is 110mm, but the problem is that my front bar is so much longer than most, it cops a hiding just driving down a bumpy road, its stupid, simple answer is that if u want a low car, cracks and scrapes are inevitable.
I got a 400R bar on my skyline as well. Not only is it sit a little to low, it also sits forward a bit more than a lot of other bars making slightly steep driveways / gutters etc a bit of an issue also.
The skyline still sits at standard hight, so i will be replacing the bar before i drop it.
leigh.
When i bought my car with the 400r front bar allready on it, it was 70 ****ing mm off the ground! When i went crusing for the first week through most of the ' lap ' spots i could not drive over the speed bumps, i could not drive into certain drive ways, i could not drive into my own driveway, i could not get into servo's or bloody anywhere. After cracking the shits and the bar a few times i got the springs done and raised to 110mm, which still i have to go up certain speed bumps and driveways on angles, which sucks big time, but most things are allright, you just have to go up slow, then it's all good. I would suggest about a 130mm ride hite, it's still pretty damn low but you should be able to navigate most things straght onwards, this is with 18's aswell. I also believe that you need some sort of bigger side kirts otherwise the bar does tend to make the car look big at the front with the stock skirts, nismo side skirts are good and look the part. Overall the 400r bar is awsome, it gives the whole of the car a much more aggresive look, it almost looks evil. Get it!
I gave my Bomex front bar a good crack when i misjudged the distance to a kerb at uni. It's the worst feeling in the world. What made it worse is that the bar is still around legal height, n bumps and anything else are no problem. Sometimes the fact that an aftermarket bar juts out a little bit more than usual can get u into trouble too. The bar is now actually cracked, but not where u can see it...just underneath. sux!
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
