Good stuff,
Can you post pictures of your fuel line routing and the location of the FPR?
So I stop considering and got shit done yo!!!!
With 750cc "Xspurt" stubby (40mm) injectors ,it fits like a glove :bunny:
And they told me it couldnt be done..... :happy:
this is about the best pic i have, this was just a test fitting
the reg just squeezed in there, you can see the return line goes straight back to the dampner and the feed hose goes around back of the manifold pretty simple..will have a gauge in this line somewhere too..was at EFI Hardware today he also does a kit to fit 55mm injectors in there...very tight squeeze but a nice kit..
Nice,
Thank you ... I was thinking about mounting the FPR directly to the rail as you did.
Was not too sure if that solution would be mechanically sound??
Alas that would save you one additional fuel hose. (FPR to RAIL)
Space is tight there, have to see if my FPR does fit.
Thanks! :)
Edited by Torques
Does anyone know if the R33 RB25 fuel rail will fit the NEO? Retaining the factory plenum of course.
I'm going to put Xspurt injectors in my NEO and i need to either modify the stock rail and put -8 fittings on it, or just buy a rail off the shelf.
I'd prefer to just buy one off the shelf.
I like what youve done there mate :thumbsup: very good work!
with the bung go to a bolt shop and get an allen key grub screw for it, use some fuel resistant plumbers tape and your laughing!
So if i can use an R33 RB25 rail on an RB25 NEO, does it also suit an RB26?
Another question, do i have to use 3/4 length injectors or can i get away with full length injectors with the NEO?
I assume the fuel rails come with fitting kits to suit either injectors?
Any reason to go with 14mm injectors over 11mm ones and vice versa?
ferk me well i been to a couple of bolt shops and a speed shop and nobody has the right size bolt/grub screw i neeed..from what I can tell its a 9/16 UNF..
I do have a fitting for it thats too long, so looks like I will have to tap a thread through the fitting put a grub screw through the fitting then grind it off flat..should work ok..
I run an RB26 HKS rail on my car, i recently purchased ANOTHER HKS rail as some idiots lost the HKS badge off mine after it had been powdercoated so long story short i purchased another HKS rail to steal the badge off it, the new one i purchased is to suit ER34 NEO and R34GTR, it looks almost identical to the one i have fitted so no idea what the difference is... It suits 11mm injectors to my knowledge. Mine fit as it was a forward facing plenum, the other HKS rail will be for sale if you need one.....
:cheers:
Turns out 'InjectorsOnline' had it after all.
I just had to be patient and wait for him to get back to me, Something I am not real good at :no:
Oh yeah heres a pic of my XSpurts Torques, bit different to yours hey..how many cc are yours??
Look how cute they are , believe it or not they're also available in 2000cc in this size..:blink:
About 540CC ..
They're Bosch EV14 (and almost double the length of your injectors)
http://www.bosch-motorsport.de/content/language2/html/2659.htm
But the ones I bought have Ford Motorsport (USA) (Mustang GT500) part-numbers.
http://www.lethalperformance.com/07-09-shelby-gt500-fuel-delivery-fuel-injectors-c-2052_2271_2274/bosch-72lb-ev14-high-impedance-fuel-injectors-set-of-8-p-17814
  • 1 year later...
I think they can modify the pintle tip for any size. Just go the 2000's Disco, better resale value. ;)
That said, the smaller the size the cheaper for some stupid reason.
I went to IDs site to see what their range is and came up with two possibilities . It seems that Gen IV Chevs run this style of shorty injector I think in LS3 LS7 and some later truck versions . Injector Dynamic do one in this size called ID 850-GM so if you want the claimed to be blueprinted version with a 14mm top ID can supply .
The other possibility is the ID 725-48-11 which means 725cc 48mm long 11mm OD top section .
Scott at Insight says he has not used the shorty Xspurts but the 48mm long ones work well and virtually same as the IDs .
I have looked at pics of R34GTt rails and I think their supply and reg tubes would be a nightmare to fit under an R33 plenum , Nissan didnt plant their R34 reg on top of the front of the rail like they did with 33s . To have any hope of using an OE rail it would have to be from an RB20 or 26 , which means 11mm top O ring injectors and the shortest EV14s I think are 48mm long .
For the record has anyone successfully used an RB20 or 26 rail on an R33 RB25 std manifold and is there much difference in their mounting points .
I think I have an R33 RB26 rail here burried somewhere .
I know an aftermarket rail is easiest but it would be nice to have the fuel lines and reg about where they should be and looking standardish .
A .
I modified my stock VQ rails, tigging 6an fittings to the end of them, but I am fairly sure Proflow do a nissan reg adapter fitting if you want to run a hose off the rail where the reg was. Perhaps just relocate the stock reg if you don't want adjustability? I went aftermarket with an SX reg, no issues in 3 years on ethanol.
If you are looking for stealth, the side feeds may be the best option.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
