  • Replies 51
Do you have the interior piece that runs around the rear quarter window
both left and right hand side. The plastic has to be perfect no cracks splits
or anything.
i want all four door trims if you have them condition not important(as long as not broken trimming condition not important).... let me know asap as im in the stages of ordering some off another...thanks mate...
have the ecu, have the center console container lid/elbow rest. have the windscreen vents, have the brakes, have the steering wheel in good nic and the standard gearstick knob. i just pulled the engine and gearbox out today. have all the seats except for the drivers seat. ive sold the chassis with tha panels except for the front left quarter which is not dinted or scratched. will get pics of all these parts soon if i can get my mates camera. i've been nagging him for it for weeks.
its only a 2 door. the door trims are with the doors. which are with the chassis. sold sorry
