I currently have a R33 GTR with a Autronic SMC ECU and Autronic CDI.
I have purchased a new engine loom as the one in the car is a total mess!!!
I know that I need to hack into the new loom to install the Autronic ECU and CDI but was wanting to know peoples opinions on a Power FC over what I currently have?
I am only looking at the Power FC as i wont have to hack into the new loom as it is a plug in.
If I was to keep the Autronic, is there any other option to modify the loom rather than destroying the new one?
Cheers in advance
https://www.sau.com.au/forums/topic/372623-best-ecu-option-for-r33-gtr/
Rewire the whole thing, all problems will be solved, including the fact that the factory wiring is crap by now
I will be rewiring either way, I have already purchased a brand new genuine loom
Just need to work out what ecu I should go for as per my first post
It depends on what you are using the car for, what mods you have and your budget.
Waste of time if you only bought a new engine harness as it's usually the power harness on the left hand side that is the worst
The car is already modified enough for what I am wanting to achieve out of it.
347awkw
Car will see more track days than street driving, it is not a daily.
Reason why i purchased a whole new engine harness is because it has been hacked into in a lot of places, have been told the easiest and cleanest way is to replace with new. Which is what I am doing
Both ECU's will do the job but I imagine the SMC would have a few more input/ouput options for things you might want to add later
Is there any other option of how to install the SMC? I prefer not to hack into the new loom if I dont have too . . .
I have a few spare female GTR ecu connectors you could have $20 + postage or pickup just wire it into the autronic and plug it in.... its how i do all my wire ins..... allows the cars loom to remain intact so it can be returned to std in minutes.
Dont want this to look like im hocking parts, just a suggestion.
Keep the SMC its a great ecu, different but great.
Ye as Dan said, depends on what you want ultimately.
If you want to log a few extra things. Keep the Autronic.
If you don't then the PFC will also be fine.
Most circuit GTR's in Vic that are still street driven on occasion all use a PFC.
When you go out & out racecar, extra logging can indeed be handy etc.
You'll need to decide/talk to your tuner & what not.
A little off topic Trent. I have the same ECU and I am interested in one of these ECU connectors for my car (33 GTR). Is there any chance I could grab one off you. I tried to send you a PM but It didnt have the little tab for to do so. pinch.gif
yeah i looked yesterday and have one left. drop me an email and i will pack it up.
yeah the autronic is a great ECU and the CDI is great too. there's also nothing wrong with a power FC. both of them if tuned well will run the car beautifully. you could swap to the power FC and sell your current autronic set-up and probably not lose any money in the process. power FC is great on a street car, they run very nicely.
really up to you. a patch look for the autronic is a fine idea though too.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
