I currently have a R33 GTR with a Autronic SMC ECU and Autronic CDI.
I have purchased a new engine loom as the one in the car is a total mess!!!
I know that I need to hack into the new loom to install the Autronic ECU and CDI but was wanting to know peoples opinions on a Power FC over what I currently have?
I am only looking at the Power FC as i wont have to hack into the new loom as it is a plug in.
If I was to keep the Autronic, is there any other option to modify the loom rather than destroying the new one?
Cheers in advance
https://www.sau.com.au/forums/topic/372623-best-ecu-option-for-r33-gtr/
Rewire the whole thing, all problems will be solved, including the fact that the factory wiring is crap by now
I will be rewiring either way, I have already purchased a brand new genuine loom
Just need to work out what ecu I should go for as per my first post
It depends on what you are using the car for, what mods you have and your budget.
Waste of time if you only bought a new engine harness as it's usually the power harness on the left hand side that is the worst
The car is already modified enough for what I am wanting to achieve out of it.
347awkw
Car will see more track days than street driving, it is not a daily.
Reason why i purchased a whole new engine harness is because it has been hacked into in a lot of places, have been told the easiest and cleanest way is to replace with new. Which is what I am doing
Both ECU's will do the job but I imagine the SMC would have a few more input/ouput options for things you might want to add later
Is there any other option of how to install the SMC? I prefer not to hack into the new loom if I dont have too . . .
I have a few spare female GTR ecu connectors you could have $20 + postage or pickup just wire it into the autronic and plug it in.... its how i do all my wire ins..... allows the cars loom to remain intact so it can be returned to std in minutes.
Dont want this to look like im hocking parts, just a suggestion.
Keep the SMC its a great ecu, different but great.
Ye as Dan said, depends on what you want ultimately.
If you want to log a few extra things. Keep the Autronic.
If you don't then the PFC will also be fine.
Most circuit GTR's in Vic that are still street driven on occasion all use a PFC.
When you go out & out racecar, extra logging can indeed be handy etc.
You'll need to decide/talk to your tuner & what not.
A little off topic Trent. I have the same ECU and I am interested in one of these ECU connectors for my car (33 GTR). Is there any chance I could grab one off you. I tried to send you a PM but It didnt have the little tab for to do so. pinch.gif
yeah i looked yesterday and have one left. drop me an email and i will pack it up.
yeah the autronic is a great ECU and the CDI is great too. there's also nothing wrong with a power FC. both of them if tuned well will run the car beautifully. you could swap to the power FC and sell your current autronic set-up and probably not lose any money in the process. power FC is great on a street car, they run very nicely.
really up to you. a patch look for the autronic is a fine idea though too.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
