23 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 211
bigkevracer NM35 Stagea 161.2AWKW
Dunc NM35 Stagea 176.8AWKW
Ruby C34 Stagea 232.0RWKW
Seems to me like the M35s are a little underpowered :laugh: This list is from yesterday's dyno day for SAU-SA. My Stag previously made 252.8rwkw on a Dyno Dynamics dyno. Yesterday's dyno day was on a Mainline.
On a serious note, SAU-SA club is going to have another track day in the coming months. Would like to see a few Stageas out there ... I'll be there to better my 1m29s now I have 70kw more and bigger brakes. Track day list is open to club members first then extended to non-members. When the clutch drops, the bullshit stops :P
What happened to the other 20kw? :huh:
not quite but similar, first the bikies, next the the hoons, soon people won't be able to gather in public unless the government can somehow make money from it!domokun.gif
So these laws still go through even tho MR RANN is getting the boot
What does a std M35 do at the wheels? I guess an ARX would be slightly higher (kw) due to the extra boost.... but a little slower due to the creature comforts.
The loss wouldn't be 40%. That would mean if your car is making 162 ish awkw its around 270 kw flywheel. You won't pick up 60kw from a turbo back exhaust.
exactly...I was gonna say so my car must be 370kw at the flywheel!!
AFAIK the loss is a constant figure, not a % which increases with power!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
