Well i am new here and my car is a s13 with a r33 rb25det s2 and i did the swap myself and got it done some months ago and be trying to sort out minor stuff...i have driven the car and even though because of a bad maf i couldnt really enjoy it i started noticing smoke coming off the alternator one night i stopped at a friends house..so a couple days later the battery died so...i said ok it was the battery cause it was a junkyard battery i was using...so now i borrowed a friend optima battery and i decided to put my hand on the alternator while the car wasnt moving or on or key turned on nothing and i just felt the alternator keep getting hotter and hotter to the point i couldnt keep my hand on it any more...i have double checked everything literally a million times and i am stumped as to what could be causing this problem..please help me i really would like to drive my car without worry about killing a 4th battery..And thank u guys so much ahead of time
Edited by Omni1026
https://www.sau.com.au/forums/topic/372728-really-need-help/
It may be overcharging. Get a multimeter and check the battery volts when idling. Raise the rpm and check the battery volts.
If there is any signs of an overcharging alternator it needs to be replaced
well sir could it be the wireharness that fubbared?? but i will actually go pick up a multimeter today and see what i get.
and as for stuff i check...i went over the engine harness...i checked all my grounds..even added more...and also go a new lowerharness to make sure the old one wasnt shorting out
also just to make sure is there suppose to be a ground on the back of the alternator casing?? i just wanted to make sure and if so can someone show me a pic of where exactly it should be and thanx again
Edited by Omni1026
When an electrical component is running efficiently, or shorting, it overheats due to wasted energy. But since the alternator also has moving parts, something could be warn internally and friction is causing excess heat. If your electronics are overvolting, you would have probably killed some crucial electronic components but its a good idea to check out the voltage asap. Any fuses popping?
no no fuses pop my ecu is not fried nothing everything is fine and all my fuses are fine...also i forgot to mention that the alternator get super hot while the car is not running and the battery is just hooked up...the only bad thing with this is that i keep destroying batteries so gave my car the nickname "battery destroyer" hahaha anyway also i forgot to mention that i can take out my alternator fuse and the car will still have power to it...so this thing is tripping me out hard
Can you borrow an (or have a spare) alternator and try that? it wouldnt take long to swap them out or ,as stated above, take it to an auto electrician who have multimeters and all the testing gear that you could think of
the issue is where i live not alot of rb or rb parts around...or else i would have gladly bought a new one
eBay or the forsale section here. You will almost definitely be able to find one and someone can post it out to you.
You have either shorted something out or that alternator is f**ked. You can get them reco'd.
well i am going over the harness as i am typing this but my question is does the alternator have a ground on the back of the casing or what??
The whole alternator is bolted to the engine. The whole thing it self acts as a ground I believe. I can't recall if it has a dedicated ground but when my last motor was pulled to sell it had the red power cable coming out of it. I can't recall for sure as I have never had to deal with the alternator but I can find out(others can to and others might know).
Just get a wiring diagram and check it out.
Here's the back of my alternator - I think it's a RB25 alternator, it's on a RB25DET in a R32.
thats is a s2 alternator and it really doesnt seem to have a ground so i guess i dont need one then...so that a questions thats gone out my mine thanx alot guys...and i may have figure out the problem will keep u guys posted and thanx alot for the help i really wanna drive it for a long period of time without worrying
:( :( :( well guys i back with another question and didnt want to make a new thread so i figured i would revive this one..Anyway on to the problem i have had this problem for far too long now and would like for it to go away its really upseting me...everytime i plug in my maf the car dies and its really annoying i cant drive my car like that in loop mode no more its really upset me i cant enjoy my car period because of this stupidness...so my question to u guys is
1..Where to u hook ur 12v power source up to cause everything i hook mine up to causes another problem on the engine..so i could like to hear from someone who has done it and have no problem
2. how does the signal ouput for tme afm really work cause i never touched those 2 wires just extended them like i should during the harness conversion but just asking to make sure i didnt do anything wrong
3.WHY DOESNT MY RB LIKE ME :( :( :(:sick: :sick: :sick:
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
    • What ECU are you running? This is probably the biggest question. If it's a PowerFC, I'd probably change the ECU and get something newer that will handle the injectors in a nicer way.
