  • Replies 234
Valid points guys. I agree with the epic story of mw2.
I just found out my brother has already pre-ordered bf3 so I'll be giving it a go on his pc. He at least has a 2600 i7 so it should run awesome.
After comparing, I'll give my two cents and provide an update.
BF has always been better, you can blow shit up, collect dog-tag ....etc.
I agree battlefield has always been better
but with your other points up until bad company battlefield had only very limited blowing shit up and was limited to a few explosive barrels
and with dog tags they were only introduced in 2142 and all BF games before that never had them
http://www.battlefield.com/battlefield3/1/beta
http://blogs.battlefield.ea.com/battlefield_bad_company/archive/2011/09/19/battlefield-3-open-beta-dates-announced.aspx
We are happy to announce that the eagerly awaited Battlefield 3 Open Beta starts Thursday, September 29th!
Running until October 10th, the Battlefield 3 Open Beta is your chance to play the game early, try out our free social platform Battlelog, and help us make the game even better by sending us your valuable feedback.
If you pre-order Battlefield 3 (PC digital download version) on Origin before September 25th, or if you have bought Medal of Honor: Limited Edition/Tier 1 Edition, you will get 48 hours early access to the Beta, meaning you can start playing Tuesday, September 27th. The full details on how you will be granted early acess is available on our new Beta section.
For Xbox 360 and Playstation 3, the Open Beta will be visible on the consoles' digital marketplaces under Battlefield 3. For PC, you need to install Origin and download the Open Beta from within the Origin application.
For all your Open Beta questions and answers, head to our new Beta section at the official Battlefield 3 site. Enjoy the Beta, and let us know what you think!
BF3 looks jawdroppingly awesome...
What will the graphics on consoles look like?
Never played fps on pc before.
Might need a keyboard, mouse, speakers, monitor, graphics card, etc, etc upgrade.
And i don't mind the look of the MW3 sunnies...
Will have to get MW2 so i know the storyline.
Don't ask me how but I fluked getting early access to the beta.
Graphics are great, everything is much more 'solid' looking.
Taxes the shit out of my GFX card though.. indoors I was getting 70-80fps on 1920x1200, outdoors it was dropping to around 40-45.
The first gun on assault class can be tricky, a fair amount of recoil but it only takes one or two blips to take down a guy. I just unlocked the rocket launcher but didn't get a chance to use it before the game ended.
I don't like the browser interface but perhaps I'll get used to it.
Slightly overwhelming jumping into a 32 man match, but still I came 2nd on my team first go
Seriously though, this game is win.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
