  • Replies 234
Since most here are PC junkies, is there anyone getting BF3 for console??
PS3 - to be more exact? :whistling:
probably me....
looking to build a tower that can run this, but i dont think i will be able to afford that anytime soon.
already have a ps3, so looks the easiest route.
playstation network name: deadener
add me, you know you want too...
For the technophiles and PS3 fanbois
It's DICE's presentation on how they've maximised the ps3 tech i.e. RSX + utilisation of the multiple SPU chips, to perform parallel processing as opposed to serial.
This is basically how the first-party games are made eg. God of War 3 and Uncharted 2+3. Actually, I remember I had also included a similar presentation from SCE Santa Monica on the GoW3 thread.
Without getting into the politics, it's good to see that not all companies laze about on the console and actually put a bit of effort into it... unlike what many PC geeks tend to advise :nyaanyaa:
Dunno what the PS3 version is like but the Xbox version looks like shit.
PC really is on a different level these days though.
The PS3 doesn't fair any better in the 'compare to PC' stakes.
Lol obviously div. PC version is unbeatable.
But it has proven to have higher textures and less jaggies when compared with the xbox version (xbox on top)
Link to article
The only reason MW3 has smashed pre-sale records is because of the continuing storyline from MW2. I'll give MW3 that - the storyline is fuarking epic and im still buying MW3.
But for realism and graphics, BF3 will SHIIIIIIIIIIIIIT all over it.
Realism and graphics are what ruin FPS. COD4 was and probably always will be the best FPS and it had absolutely no realism and terrible graphics.
A good FPS needs 2 things above all else, a good engine, so you move fluently and freely, and BALANCE. Balance is probably the most overlooked. COD4 had reasonable balance (yes it could have been improved), MW2 and BOPS don't.
With enhanced graphics and realism inherintly comes detailed maps and backgrounds which inturn bring camping. When weapons are made to be more realistic the game becomes unbalanced. An example of balance is someone of any playing style should be able to find a weapon class that suits them and be competitive to the point of their skill level with no weopon class or playing style having an overall advantage over any other. The most skilled player ie: the winner, should be the one who can adapt and excel at any playing style or weapon class required.
The single player on COD is a waste of disc space really and is certainly not what drives it's record pre-orders. The multiplayer is what sells it and keeps bringing people back.
Bottom line is BF and COD are 2 very different games that don't appeal to the same people. BF is for strategists, in COD we refer to them as campers.
I'll be buying MW3 and probably won't even glance at BF on the shelf on my way out the store.
I totally agree with what you said except for "BF is for strategists, in COD we refer to them as campers."
I was all for MW3 (even refer to my previous posts) because I loved the arcade style gameplay but after playing the BF3 beta, I've now converted and have even pre-ordered a copy.
Camping is BORING. There's no enjoyment in it. Perking up on Lightweight, Marathon and Sleight of Hand and running around was my COD style; which seems to work quite well in BF3 too.
Plus, BF3 relies heavily on teamwork to properly progress and is much less reliant on K/D ratios... in which camping is a crappy strategy.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
