SQ
bar x 10
40kg x 10
60kg x 10
80kg x 10
100kg x 10
100kg x 10
100kg x 10
Single Arm DB Rows
20kg x 10
20kg x 10
20kg x 10
DB MP
20kg x 10
20kg x 10
20kg x 10
DB Curls
20kg x 10
20kg x 10
FPR's
20kg x 10
20kg x 10
20/3/13
BP
bar x 10
40kg x 10
60kg x 18
60kg x 10
60kg x 9
Single Arm DB Rows
22.5kg x 10
22.5kg x 10
22.5kg x 10
DB Curls
22.5kg x 10
22.5kg x 10
FPR's
20kg x 10
20kg x 10
20kg x 10
SLDL
100kg x 20
DB MP
22.5kg x 5
22.5kg x 5
  • Replies 300
26/3/13
SQ
bar x 10
40kg x 10
70kg x 10
90kg x 10
120kg x 5
120kg x 5
120kg x 5
120kg x 5
120kg x 5
122.5kg x 1
125kg x 1
127.5kg x 1
130kg x 1
132.5kg x 1
135kg x 1
137.5kg x 1
140kg x 1
DB MP
22.5kg x 10
22.5kg x 10
22.5kg x 5
Single Arm DB Rows
30kg x 10
30kg x 10
30kg x 10
DB Curls
22.5kg x 10
22.5kg x 8
20kg x 8
15kg x 5
+ a few more sets at the end
FPR's
20kg x 12
20kg x 12
20kg x 12
I'm assuming there's some PL comp on Saturday? I can't unfortunately, just too busy with work and family at the moment, I barely even get to the gym once a week/fortnight/month! :(
Edited by GHOSTrun
  • 4 weeks later...
30/4/13
BP
bar x 10
40kg x 10
60kg x 10
60kg x 10
60kg x 10
SQ
bar x 10
40kg x 10
70kg x 10
90kg x 10
122.5kg x 5
122.5kg x 5
122.5kg x 5
122.5kg x 5
122.5kg x 5
Incline DB BP
20kg x 10
25kg x 10
25kg x 7
25kg x 6
20kg x 10
20kg x 7
Single Arm DB Rows
30kg x 10
30kg x 10
30kg x 10
FPR's
20kg x 10
20kg x 10
20kg x 10
  • 1 month later...
23/6/13
BP
40kg x 10
70kg x 5
70kg x 5
70kg x 5
70kg x 5
70kg x 5
Trap Bar Bent Rows
75kg x 10
75kg x 10
75kg x 10
DB Bench Press
20kg x 10
20kg x 10
20kg x 10
Single Arm DB Rows
35kg x 5
35kg x 5
35kg x 5
Built myself a small setup for home. As much as I'd like to train at PTC Brisbane, it just wasn't working for me to get their after work multiple times a week.
1011750_10151710698858945_301692540_n.jp
992891_10151715238558945_1055484413_n.jp
1013452_10151723642698945_343515929_n.jp
941709_10151723675503945_1200390835_n.jp
Haven't finished trimming the bench yet because I'm still playing around with the foam specs to get it how I want, bit more trial and error.
1/7/13
Squat
80kg x 30
90kg x 3
100kg x 3
120kg x 6
130kg x 6
140kg x 2
Pause Squat
100kg x 5
100kg x 5
100kg x 5
1/8th Squat
170kg x 5
170kg x 5
170kg x 5
Front Squat
70kg x 5
70kg x 5
70kg x 5
Shadow of my former-self, would like to get back to where I was, will take some time though, at the moment I just have no passion for lifting, and when something that's supposed to be enjoyable becomes a chore, why do it at all. The bug will bite again, it always does, just get sidetracked with other stuff in life every now and then etc.
  • 1 month later...
  • 3 weeks later...
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
