Hi, I recently bought my first skyline, Its a ECR33 GTS25T, in fact its my first car new enough to have fancy things like air con, and power steering. (My other car is a LH Torana) So I have found myself a little confused about all the fancy things in my new car. After a bit of playing i have mastered the power windows, mirrors, air con, and the other little gadgets, now its time I move onto the things that make the car ZOOM! First of all is the turbo, it has a HKS GT2540 Turbo kit. Now for me that sounds fancy but other than that I cant tell you anything, all I can find on the net about it is prices, how can i find specs/instructions or any info for this turbo?
I also have a GReedy B-Spec boost controller, Like the turbo it also sounds fancy, and it has a button that turns it from crazy mode into CRAZY mode. But how can i tell if this is set up right for the turbo/car? Or should i just be safe and leave it in crazy mode and forget about CRAZY all together?
Also if theres anything else I might have missed, or you think i should know about please let me know, as I really have no idea about the car at all.
Heres some other fancy gadgets it came with.
  • HKS GT2540 TURBO KIT
  • NIGHT PAGER DUMP/SCREAMER
  • GREDDY BSPEC BOOST CONTROLLER
  • GREDDY VSPL FMIC AND 19 ROW OIL COOLER KIT
  • TOMEI FUEL PUMP
  • NISMO 555CC INJECTORS
  • TRUST E-MANAGE COMPUTER
  • SPLITFIRE COIL PACKS
  • ADJUSTABLE TEIN COIL OVERS
  • GREDDY TURBO TIMER
  • 3" TURBO BACK EXHAUST
That is just high and low boost. If it was setup right, and the guy you bought it from had the car tuned at a reputable place, I wouldn't give anyone money to start fiddling with it. If its making power and not knocking, why burn money.
Nice turbo too, very responsive piece of kit. Don't change anything on it. It looks like some big money and time has been put into it. Enjoy it and when you feel you need more, strap on a hypergear.
+1 take it to a reputable shop and have them give it the once over.
Have them run it up on the dyno to make sure its all running safe.
Then enjoy what youve got :) (dont listen to anyone telling you your turbo isnt the greatest one.... just enjoy what it is for now as im sure its great).
GL
isnt a 2540 like old tech HKS...??
shouldnt it be 'when you want some more bolt on a garret or a larger HKS'
Why? The turbo's that Tao has been working on recently really has sunk its claws into the top market turbos. Sure garretts are good, but they are generic turbos for any car; no specific application. These hypergear turbos are designed, built, and tested for RB motors. I know where I am(and have) putting my money. No dicking around with spacers, custom dumps, wastegate setups etc.
Take it to a reputable workshop and get them to give it a once over.
+1.
If I were you I would go and get it serviced; you never know what oils the previous owner was using or how long they have been in there, etc. Might as well get them to check general things like boost controller settings, and all that. Won't cost much, and for the peace of mind it would be worth it.
+1.
I got quoted $900 for a full once over, $1500 if I wanted my timing belt changed too and $1900 if I wanted my injectors cleaned. Told them to stick it. I changed all fluids my self, flushed radiator etc all round then had the car on a dyno. They told me the power, tweaked my power fc and told me it was safe to go. $90 spent on the dyno run and tweak.
When you move to Skylines, there are alot of things you can DIY to save money to pay for things you can't DIY!
HKS turbo kits are designed for their application as well, but they have been doing it a hell of alot longer and known to produce responsive setups with no 'dicking' around...
I dont believe there is any 'the best' setup, its what works all feels good to the owner unless your in comp...
but to say "Nice turbo too, very responsive piece of kit. Don't change anything on it. and when you feel you need more, strap on a hypergear."
Ive read, no, its not a responsive turbo compared to other HKS', and strapping on a hypergear is just one of many options, not 'the' option...
Lol at $400 for injector cleaning. The other stuff is ridiculous as well. Sounds like the workshop was trying to take advantage of you.
I do agree, I DIY most things on my car. But judging by the OP's post, he doesn't have much experience with these cars/engines. In my opinion, he should get it serviced properly and well checkout out the first time. There's a lot that could need changing that he might look over if just changing the oil, ie. belts, brake pads, rotors, etc. etc.
Then once he has had the car for awhile and has got some more experience with it, DIY to his hearts content :)
Yep without a doubt - take it to a workshop that you intend to use moving forward.
Get them to check it out. First thing i would do with a new purchase that has modifications.
Also a full oil change (diff/gearbox as well), always a good idea as you never know the last time it was actually done by the previous owner etc.
Yes totally correct. The HKS2540 is a old tech turbo unfortunately. Much better choices on the market now for 4-5 years
Certainly the first place to start if more power is wanted.
You will be surprised. :D
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List: 1.Anna S 2. Luke S 3. Jesse Givens-Lamb 4. Luca Stamatescu 5. Madeleine Stamatescu
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
