You can make one for about $0 - $10, if you're a bit handy. I saw a how-to on the forum a while ago. Did it differently to me (probably better lol) but was more involved.
Nissan will charge you about $90 for it, but if you pop off the plastic cover then stick some rubber or stiff foam around the edge to stop hot air getting in, you'll end up with the same result.
Of course it won't say "Poooowweeerrrr duct" for everyone to see when you open the bonnet......
https://www.sau.com.au/forums/topic/373116-want-a-part/#findComment-5955624
It will if you get a white texter and put it on there :D
https://www.sau.com.au/forums/topic/373116-want-a-part/#findComment-5955711
Yeah, try $180 :whistling:
dodgey DIY is not the look im after.... thanks anyway
Lol @ dodgy DIY...
Guess it depends on your skill level...
Go to a Nissan dealer and ask them for one; they'll happily unload your wallet for you.:thumbsup:
https://www.sau.com.au/forums/topic/373116-want-a-part/#findComment-5956475
Yeh for OEM you have no choice but nissan unless you can find one on ebay, you may be able to pick one up 2nd hand from the US on the ebays
Just did a search
http://www.ebay.com.au/itm/Airbox-G35-K-N-filter-Air-Box-OEM-/270781929440?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f0bdc57e0
thats all i could find.
Edited by T4NK
https://www.sau.com.au/forums/topic/373116-want-a-part/#findComment-5956903
Lol @ dodgy DIY...
Yeh, pushing over 300kw with my dodgy diy duct. ;)
https://www.sau.com.au/forums/topic/373116-want-a-part/#findComment-5957282
sorry i'll elaborate on that....
im not interested in the fictional power gain with this mod, am just in need of the OEM part that goes here
Umm, I'm confused. If it's a fictional power gain, why are you so interested? I'm not saying you will get much (if any) gain (as opposed to us M35 owners), but wouldn't you like to try a zero cost mod to see before being touched up by Nissan or anyone else?
If it's only about the looks, put the money towards something that can be seen on the outside IMO.
https://www.sau.com.au/forums/topic/373116-want-a-part/#findComment-5958308
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
