$500 for installation and Oil is a good price imo......but no more than that!spank.gif.......it's about 4 hours work with the correct tools.....but 1 stuff up and your screwed!
try this when pricing......tell them it's a 350Z auto...that they will understand...it's the exact same shit.
http://g35driver.com...ml?ref=esp-link
have fun!!! :P
I've read that guide before and it doesn't look too, cough, daunting.
My local guy knew the gear box, but didn't spend anytime reading what was involved with the kit, hence the price range. Been caught before tho, ends up being $990 + GST, not $500, lol.
4 hrs should = $280 to $400 ($70 - $100/hr) plus oil. So $500 would be the absolute max that the job is worth IMO.
Meh, just gonna do it myself, even if it takes a whole day.
Edited by Commsman
  • Replies 183
I ordered mine. Wasn't going to but you mentioned Paypal and I knew I had money left in my account...
Guess I better suck up to dad to give me a hand too... looks like a bitch of a job!
Yep I've got oil. I'm hopeful it won't go wrong!
What's the go with your changeover version? You do the hard core valve body modding and we just fit it?
Backup plan if dad doesn't want to do it is get someone like MV Automatics to do it. No idea what they'd want to do it though.
yup...you send me your kit(or I can supply at your cost)....I'll do the upgrade to the spare and send it back.....you change it over and send me your old one.
that way your car's off the road for the minimum amount of time.
So your price is $500 for the kit supplied and installed? How much just to fit the kit if we supply it?
Im thinking of finding a shop here to fit it if I decide not to have a crack. This way I will get some sort of warranty and back up service. I assume you won't offer any type of warranty if the kit turns out not to be installed correctly? Not saying this will happen, just looking at options if a shop only charges a small amount more and it comes with a warranty/backup service.
Well obviously us being in Adelaide, Craig's just going to fit it to his exchange VB, or yours if you send it up, and you have to install it in the car (which still looks like a shit job...).
I wouldn't think you'd need a warranty with Craig, but if the shit hit the fan I'm sure you'd get looked after.
Sorry mate, that was direct at bigkevracer.
Dads a diesel mechanic, workshop at Dry Creek. He has a shed out the back he uses for his rally cars, with a hoist. Thats where I do my stuff.
Im not going to stuff around. Im sure he can do it, he just might not want to. If so Ill call MV.
Nice, hoist at home, what more could a guy ask for.
Yeah Im thinking of asking MV to fit it also but Im not sure if he would as he doesn't think a heap of the kit for some reason. When I spoke to him he didn't say he would fit it if I wanted, he just said it not worth doing this kit and gave me no other option. Very weird. I hope he would fit it as having a shift kit previous;y done by him I know his work is second to none.
Time will tell I guess.
His loss, No chance the box will hold the torque this engine can produce without it, 4 of us have proven that now and Cihan will definitely ask for it to be done before he will tune another.
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
