  • Replies 95
Guest mark32
Here is the car i helped crew for, unfortunately it had an off and was out of the race, after it went to hot over a deceptive crest at the ross stage on saturday. Up until then this the car was perfoming faultlessly with only routine maintainence being done on it. If anyone has some footage of it, would love to see it. I saw some footage of the accident on saturday night on channel nine in hobart, but would like a copy so if anyone has it please let me know
hey mark32, that doesn't look to bad after all. Apparently it did make the channel 7 news but we all missed it :) They were running 46th when this little "incident" happened so they were going pretty well for newbies :D
While I wish that skylines would have had a better result but knowing tony, I would rather he get the result...
Always next year!
BTW he only had the current car for a few months... If it is any consolation it was in teh S202 which is a factory homologated car for these types of events, sort of lilke the Nur Spec GTR's
So that isn't your car mark?
Whoevers' car it is will be really pleased with your expose! BOV looks like a non Nissan item to me...
To all those who finished, well done! To those who tripped up, chin up...
Targa is like a drug. I have just had sponsors meeting and received commitment for next year.
But regardless, it is a 4WD event, and when we front next year - it will be in a 4wd.
Don't know category 8 or Cat 9... Some pics on our review link.....
Thanks for all those who showed interest. To the marshalls and volenteers... without you there would be no Targa. And Sydneykid, for his personal assistance - I'll send you the graph Gaz - to put a competitive package on the track.
Love yus all, TT
Photo courtosey of
http://home.iprimus.com.au/cybernoir/targa2004/two/
so I'm guessing that Bovs must be standard then?
My appoligies for not reading the rules, I'll take greater care next time. :P
Do you know what the ruling is on exhaust systems, some gtr's had standard exhausts while others had much larger non standard items
The pipe is to be the same diameter external as the OEM item immediately before the first muffler/cat
I would suggest some pipes in Targa are not legit, but the people get away with it cos they are running outside outright contention...
Ask the R34 owners in this years event... I believe they were copping some heat from a certain Black Monaro.
The exhaust rule is Exhaust: It will be possible to:
either remove the inside of the original silencer,
or modify the exhaust from the first silencer to the exit, the maximum
dimensions of the duct being those of the pipe situated upstream of the
first silencer (see drawing No. 254.3). Should two inlets exist in the first
silencer, the section of the modified duct must be less than or equal to the
total of the two original sections.
Only one pipe may be present at the exit, unless the original part is used.
The exit should be situated in the same position as that of the series
production exhaust system.
These liberties must not entail any bodywork modifications and must
respect the laws of the country in which the event is run with regard to
noise levels.
Additional parts for the mounting of the exhaust are authorised. If an
exhaust silencer is added, it must be of the original type and must contain
noise-absorbing material.
If it is fixed directly to the manifold, the catalyst may be replaced with a
conical part of the same length and with the same inlet and outlet
diameters. After this part, the exhaust will be free with a tube diameter no
greater than that of the outlet from the catalyst.
Note: The above regulations were written to cover under 2.5 litre, front
engine cars for rally use. A number of vehicles that are entered in Targa
Rallies have exhaust systems as standard equipment that cannot be
modified to the above regulation. Note therefore the following clarification:
Competitors with vehicles which have an exhaust system fitted as
standard equipment having two separate pipes, each routed down
opposite sides of the engine, are permitted to modify the exhaust as
follows:
(i) The catalyst may be removed and be replaced by a part having
the same length, and the same inlet and outlet dimensions. At
no point may this part be any larger in diameter than the largest
inlet or exit dimension;
(ii) No pipe in the system may be of a larger diameter than at the
corresponding point of the original pipe;
(iii) The silencers may either be replaced by silencers of a similar
type and containing noise absorbing material, or it is permitted
to remove the inside of the original silencer.
(iv) The exits shall be situated at the original position as that of the
original production exit, and the original parts present at the
exhaust outlet must be re-used.
TT
!!R4 on Cr.
The footage made the Targa Party Tape... and I'm sure it will make the TT04 Tape which goes to air in Tassy Late May, TEN network in June.
Did your team do a recce? See ya next year
TT
Guest mark32
by recce do you mean writing their own pace notes? if so they did not, they were using someone elses and they told me it went like this "r5 on crest", no double cautions, if it had the double cautions they would have gone slower over the crest and i dont think that a 5 corner was the right call either, says a lot about being careful with using other peoples notes
We actually transfer all the TS road book comments to our notes - (we do our own) - and this helps if we miss something. The hardest thing is to keep notes consistent, and even the pro's lack that sometimes...
R5 in a 1-10 format is about right, its the "ON" part that catches most out. Even so we have ours noted with a "care", but I know the course and wasn't flying blind. (didnt help at Sheffield though)
See ya in '05
TT
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
