10 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
So what would you buy? Im in the market for one at the moment.
GO PRO - $299
http://gopro.com/cameras/hd-motorsports-hero-camera/
Basic info:
1080P recording
Up to 32GB supported memory
5MP
Variety of power sources supported
CONTOUR HD - $249
http://contour.com/products/contour-hd/specs
Basic info:
1080P recording
5MP
Charge via usb so ability to charge in car
DRIFT HD - $399
http://driftinnovation.com/drift-hd-action-camera/
Basic info:
1080P recording
Screen on camera to view playback
Remote control
9MP
Up to 32 GB supported memory
https://www.sau.com.au/forums/topic/373569-motorsport-cameras/
Pay the little bit extra and get the Drift HD cam. If for drift practices etc then you can check while you wait in the lineup and see how the footage is. Since its recording in 1080P and there is only up 32GB of storage space I would say that it won't be long before the memory gets full. So check and delete the ones that didn't turn out right might be the go.
If your using a 32GB card on full 1080 HD it'll last 8 hours of recording time....BUT the battery life of the above cameras only last 2-3 hours (can recharge in between sessions though in the mallala sheds).
I'am about to buy the gopro...there all basically the same specs but I have seen the gopro used and the results are good...it also comes with the best mounts...I don't want to lose that sucker at 200kmph!!
I have purchased the contour gps version for a couple of reasons.
It seemed pretty widely used and recommended.
It has the gps which gives a speed reading.
Watched plenty of YouTube clips that seemed good.
But the main selling point for me was that its not only recommended as a motorsport camera but also as an underwater camera. I do a bit of scuba diving so I just buy an underwater housing and go diving. I think the go pro has underwater housings available too.
That's something to think about. Uses other than incar.
Ps. it hasn't arrived yet, purchased last week. $320 delivered for the gps version and windscreen mount.
go the radcam. ive got a gopro, sound is crap. wind noise is REALLY bad and it takes pretty average video in low light and is almost useless at night (eg drift pracs). also if you get the bluetooth card thingo for the contour you can use your smartphone as a remote screen and controller so not really worth getting the drift hd if the screen is the only extra
also i wouldnt trust the suction mounts on any of them, i always add some race tape for extra piece of mind.
sound quality is still there (not as good as the rest, agreed) but that's just an excuse to throw down some background music on your footage. Picture quality is the main thing. The gopro seems to include the most accesories like all the mounts and waterproof box etc where as all the others have to be purchased seperatly. Just comes down to budget I guess, the best of the lot like posted above would be the $475 radcam.
At the risk of looking like a video whore, here is some Radcam footage. I normally place a little microphone sock over the supplied Radcam microphone to tone down any wind buffet, but for this day I'd forgotten to romove it from my own car (I borrowed this Evo).
Still, gives you a good idea of the quality available straight out of the box. YouTube still dumbs down the quality a bit, but if you select 1080 its quite good.
Go Pro has it's place. Ken Block uses them extensively for Gymkhana because they don't have a remote box, so they're easier to mount around the place.
It all depends on what you're planning on doing with it, where it'll be mounted, will it be permanently mounted, etc.
I'm your SA RaceRecall.com dealer, so Radcam mainly, and I have a couple you can try out if you'd like.
I have heard some good things about the Drift HD and we should be getting those soon too. Heard interesting things about the Contour too, but no experience with them so far.
PM me if you want to check out the Radcam.
Ill be honest, at this stage im leaning towards the Drift HD, it will be mounted on various points of the car and itll be so much easier to just press the button to play or stop recording.
The remote is fairly common, the Radcam's have those. So if you're specifically after that, you still have a choice! I think the POV does too, but that's a fair bit dearer.
Something to think about with the Radcam and POV type camera is it has the camera head on a cable to the body, so you can mount the camera almost wherever you like internally (and even externally to an extent) and have the body with the controls next to you.
Radcam comes in a kit with the heavy duty mounts, suction and roll bar, so you're all ready to go out of the box. So it's a bit dearer but you also don't need to worry about anything else.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
