  • Replies 91
I got a twin plate exedy put in last weekend, with a new thrust bearing from nissan...
Its been perfect all week... the pedal is heavier and the engage point was only just up off the floor (how a new clutch should be?)
Last night something must of happened because the engage point is now all of a sudden all the way out (like my old clutch was just before it died)...
any ideas what this would be?
is there much involved in getting a Nissan patrol clutch into my R33?
Its it a bad or good idea?
What kind of parts are involved other than the clutch plate?
They are very heavy and thus slow down the response of the engine, kinda the reverse of a light flywheel.
You get a fricton plate, a pressure plate and a thrust race in the kit.
Hope that helps :)
thanks Sydneykid for clearing some up....
so, rattle is normal...even though its so loud normal ppl thinks ur car is stuffed :(
pivot ball hasnt broken - i've whitnessed my other bros gtst when that happened...
Emre - yep its a secondhand orc twinplate... very new though 3.9mm plates...
i have tried bleeding it again.....this time taking out the dampener system as well
like my 180.....to bleed the slave cylinder it needs to be pushing against something right?
ie. clutch fork > pressure plate.....i found that it wasnt going anywhere until i physically
pushed the fork against the S.cylinder then it started to pick up...
i dont think anything is broken......at the start i thought that i might have machined
a bit too much off the carrier too but why would it work fine during the 500ks?
which leads me to believe that somehow somethings moved, but how?
when bleeding i tried putting something between the fork and the S.cylinder tip and it
felt much better (pedal) but didnt wanna try starting car on the stands....
i will probably remove the dust boot and take a look inside..
  • 1 year later...
Hey Sk - old thread and all. I have a Patrol clutch in my car.. are they heavier than the equivalent skyline HD clutch (single plate)?
Seems to feel like a decent clutch but am I loosing out on a bit of response?
Not that I'm going to change it but wondering what power it is good to - around 230rwkw?? Its a bit over a year old - so pretty new still
Thanks
Edited by benl1981
Can anyone confirm for me if the series 2 r33 gtst has a pull type clutch or a push type clutch.
Steve,  where did ya get your twin plate os giken from?
i have a series two gts-t and it is push type
hey i have read a heap of these clutch threads and cant find a straight out answer. I need a clutch to hold around 280rwkw in an r33 series 2 box...
im assuming launching in a button in the wet up hill in traffic is impossible...so i am wanting to avoid that....what are my options?
Thanks for the advice in advance.
Old thread but I'll thow my 2 cents in :)
I've just installed an O.S.Giken TSR2CD Twin Plate Clutch and so far I'm impressed !! It has a MUCH lighter pedal feel than the old TS2C/D and TS2B/D. It has the same feel as a stock GT-R clutch ( which takes a lot of getting used to :P ). It's still rated to 600hp at the engine and is very driveable. The new clutch kit comes with a new release bearing and carrier already assembled. Cost is around the $2k mark but is SO worth it when you next get caught in traffic :P
BTW If anyone wants a really good 2nd hand O.S.Giken Twin Plate Clutch that will hold up to 250rwkw for R31, R32 or R33 at a great price, PM me :(
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
