does it matter if its legal or not? why bother installing an anti-lag system unless its a track/rally dedicated car??
..it aint gunna get you to westfield any quicker.
Edited by adamskill
You signed up onto SAU to ask whether shooting 1m flames from your exhaust at a set of traffic lights is illegal.....hmmm let me think....
Jokes aside, ive always wondered how antilag works. Very interesting read on wikipedia, like how the restrictors they use create more lag then a normal sports car so the turbo needs to be going stronger before they put the foot down.
http://en.wikipedia.org/wiki/Antilag_system
on the street would be useful if you had a larger turbine and wanted to go on a spirited drive, although its probably very illegal and probably harsh on your powertrain.
I would think the exhaust with mufflers and cat converter would be blown out in a few minutes on the street.
definitely belongs in motorsport though.
Its not stress on the drivetrain you need to worry about.
Its stress on the motor/turbo. That's where the issue is. You'll be replacing turbos quite often if its used even semi-regularly.
thats what i meen,he would be burning through exhaust valves quicker then the turbo though.
I setup antilag on the Vipec for shits and giggles (it's not 100% setup as I'm not that keen on it). Definetely not good for your car though.
You sure Evos have it from factory? What models? I've never heard that before that's all.
You mean proper antilag for between gear changes or just launch control antilag? (I wrote up a post in the past explaining all the different things people refer antilag to but can't be bothered finding it).
Evos do not have antilag from factory.... I used to have one and two of my good mates have them
some of them do. it is a pretty watered down system though. also in some cases it is disabled in the ecu. basically it is put on there as a provision to get around certain homogolation regulations in certian rally classes (group N i think). so basically some of them have all the gear, but it isn't turned on. not sure what models do and don't, but all i know is that the info above generally applies to the evo 3
Most evo's have the "missfiring system" from the factory, it is something that can be turned on in the ECU ( many of the evo ECU's are factory flashable)
You can see the pipework in an OEM engine bay !
However many owners can and do remove it, because for most people having it is irrelevant.
Also,
If one forces sex upon a prostitute is it rape or shoplifting ?
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
