I have done a search but cant find a definate answer....Engine is rb26dett.
If using twin 044's, with twin entry rail etc, will 800cc injectors be ok if i just bump up the rail pressure, and If so to what power level?
My 800s are pretty much brand new sards so If I could keep them instead of having to buy new ones that would obviously be the go.
Any help is much appreciated. Cheers
  • Replies 74
Given he asked what power level - estimated you'd say 400rwkw would be the limit. Maybe a tad more, maybe a tad less.
With bumped rail pressure my 700cc Sards are @ 65% max duty with 360rwkw on PULP (20psi).
So 400rwkw on 700cc/E85 (allowing for 35% extra fuel) would be 100% duty with the bumped rail pressure.
So you could say the 800cc on a 2.6ltr might just scrape in. But you won't know till you get there.
We have seen a couple now max 1200's at 600hp on the nose at the wheels. That is tuned logging individual cylinder EGT's.
The others that we have done seem to come in at around the same ratio so I would say 400hp at the wheels would be a fair guess as to what you could make safely on 800cc injectors but as N1 said, every setup is different and it will all come down to fuel flow and the rest of your setup.
The car we just had tuned on 1600's made 610 on 22psi and uses just over 9L/min of fuel at peak power. Not sure on the duty cycle yet but I can report back if anyone is interested (could calculate also but not sure on the exact L/min rate right now).
We are also about to wind 2 bar into it and crack 700 at the wheels. I can report findings on fuel flow and injector duty if it will help you guys out?
Yeah cause as we've seen, some tuners love 10:1 AFR's lol.
That is certainly going to damage the duty cycle.
And rightly so. If you can't run 10:1 in places of your tune then your fuel system is inadequate.
Every car we have tuned runs 10:1/10.5:1 at some point. Usually at peak torque or there abouts. But then again, none of the stuff we have tuned anymore ever blows up....ever and it's only since using this tuner
Ok well I wasn't really after a smart arse answer, I realise every setup is different but anyway the car is running dash 5-s, vipec, cams, etc.
At the moment it only has single 044 intank at 320rwkw
I have a fuel system for it consisting of 2x 044 twin entry rail and at the moment only the 800cc injectors fitted.
Wow have you got a flow gauge that does 9l/min - where do I get one of those?
You trolling me or are you just clueless?
Calculated fuel flow based on the EXACT ms open time of the injector at peak power. The injectors are being told to deliver that exact amount of fuel. So where to get one? windows has a calculator or you can buy one from any newsagent
I'm now seeing 620 rwhp on E85 with CDI ignition allowing/accepting much more fuel. This is despite my modererate 2860-5 low mount turbo setup. My HKS 1000 CC injectors are at full duty cycle at max torque.
In hindsight, I would have gone to ID2000 (2000cc) injectors as the HKS units weren't "plug and play" in any case.
I'll take the opportunity again to express how impressed I am with the billet.net.au CDI kit (M&W CDI + bracket + harness etc). The spark strength allows bullsh*t amounts of E85 fueling midrange and just wakes up the turbo response. Forget your Splitfire/Twinpower combo.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
