  • Replies 130
  • 5 weeks later...
  • 4 weeks later...
ill think about it, how much is it going to cost?
Put aside... I don't know... $5000? Thats a broad question dude, do you want to live it up or go cheap?
Btw, TAS 2005 members, I'll make a new thread where we can discuss a plan of attack for the show, I don't want a repeat of the last one where we meet up twice throughout the whole day and thats it... oh, and Troy and I WILL be there on time this time!
Is Christian coming??? He should come...
https://www.sau.com.au/forums/topic/37474-tas-2005/page/3/#findComment-950982
There's talk on the gtr.co.uk site of going to TAS 2005...I expect a fair few Brits will be making the trip over again, so it'd be good to organize a meeting point for all the members. Does anyone know how to get hold of press passes - going on the Friday, before the mega crowds would be ideal...
https://www.sau.com.au/forums/topic/37474-tas-2005/page/3/#findComment-958339
Troy/Justin: I know what you mean, from Osaka to Tokyo is a long haul, especially if you're trying to get to Tokyo by mid morning - so how's about arranging to be in Tokyo the day/night before...perfect opporunity to go drinking and it'll mean getting to the Messe the next morning (if you're sober :D) shouldn't take too long....;)
https://www.sau.com.au/forums/topic/37474-tas-2005/page/3/#findComment-969954
  • 3 weeks later...
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
