You forgot the colon in http://
http://s1229.photobucket.com/albums/ee463/mick_o1/?action=view¤t=video-2011-11-02-20-43-43.mp4
you just need to copy paste the link lol. Control + V in the address bar, then press control + V in the textbox and press post = win! :)
Edited by Rolls
Lol thats what i done mate but didnt work :wacko:
I just came back from a cruise on the M4 and in top gear cruising on 110km/h i slowly wound on the juice and my car was making a squealing noise and boost was only around 10psi when it was making that noise :domokun: any ideas any1 doesnt do it in any other gear????
It might be a compressor surge? Really high load low rpm the turbo may be pushing more air than the engine can swallow
if its compressor surge you can try tweaking the tune if it doesnt do it by much.
otherwise you basically have to try make it lazier onto boost, so either lower gain settings or lift your foot slightly through that area.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
