You forgot the colon in http://
http://s1229.photobucket.com/albums/ee463/mick_o1/?action=view¤t=video-2011-11-02-20-43-43.mp4
you just need to copy paste the link lol. Control + V in the address bar, then press control + V in the textbox and press post = win! :)
Edited by Rolls
Lol thats what i done mate but didnt work :wacko:
I just came back from a cruise on the M4 and in top gear cruising on 110km/h i slowly wound on the juice and my car was making a squealing noise and boost was only around 10psi when it was making that noise :domokun: any ideas any1 doesnt do it in any other gear????
It might be a compressor surge? Really high load low rpm the turbo may be pushing more air than the engine can swallow
if its compressor surge you can try tweaking the tune if it doesnt do it by much.
otherwise you basically have to try make it lazier onto boost, so either lower gain settings or lift your foot slightly through that area.
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
