R32 Dry Carbon Parts(Doors,boot,bonnet)
if you are after cheap china carbon overlay stuff go to the sponsors section and grab a bargain
if not read on
all parts Australian made
all parts Carbon fiber, dry laid, vacuum formed and resin infused with a clear gel coat finish
This gives them a very good weight to strength ratio.
eg same shit as f1 cars
if you happened to be a world time attack and saw the carbon r35 gtr's the guy who made all the panels for them makes this stuff so its the shit
prices as listed if we get more than on order we get a cheaper price ( thus the group buy)
ill put up a price in fiberglass later if people are interested
carbon doors $3,800.00 pair
These are made to take the OEM hinges, lock and internal handles. For ease of install and operation.
They are also made to take a polycarbonate, fixed window( additional cost)
r32 boot $1800
This one is simply aero catched down but they are normally made to take the standard hinge set up.
R32 bonnet $2000
Again this one is held down with aero catches. But we can easily make it to take the OEM hinge arrangement.
Really a genuine race type of dash. $3500
dash display is up to buyer e.g. Motec, Racepak, AIM etc.
they also do a carbon roof
3k intsalled
so if you want some drop me a pm
if we get a few people wanting some the price will drop
pete
https://www.sau.com.au/forums/topic/375265-r32-dry-carbon-partsdoorsbootbonnet/
prices are out of this world.
you can get NZ made carbon bootlids for $700
doors are like 1200 a pair from NZ
same with full carbon dashes can be had from US for 1000-1200
think this guy is having a lend of you bro.
link me
would be interested to see if its the same type of carbon?
because i can get "carbon" stuff for the prices you say but its not the carbon above
it would be plug molded not vacuumed formed to start with. i don't remember the mob in the NZ starts with a R but have bought from them before. it wouldnt be up to the quality of above but for price comparison / fitment you would be out of your mind to spend the money above. on another note even some of the china stuff has extremely good fitment these days.
How u can even compare china shit to this is stupid. Pricing is fair enough as its top quality !
Just for the record I have an oem boot n bonnet as above from custom carbon for 3500 as I sold my car
Price seems very fair...
description is a little far fetched F1 technology is a bit more advanced than resin infusion.
I have a few contacts in the F1 composites world and they are all using Pre-pregs.
I am very interested in talking with the guy making this stuff, I make the same products in the same way and I would like to support his business.
You have a PM Fatz
Great to see more people out there making this stuff.
Noy
That carbon dash baby jesus smile! need to get some of this same gear but for R33's :thumbsup:
Top quality workmanship thats for sure
That carbon roof also that reminds me of that silver R32 that Garage Saurus built that was featured in HPI a little while ago, simply epic!
Edited by Weapon
The guy's at Custom Carbon can do R33 GTR parts to if cost is a bit hi for most of you they make them in fibreglass too and it's the same process as the carbon one's I think they are about $1500 and when they are painted they look and fit just right you can't compare to the shit that comes out of china.
  • 1 month later...
The panels made in nz are same build as whats in china fibreglass backed with a single layer of carbon fibre for looks.
Also fatz what do the doors with the lexan windows weigh & price on them.
cheers Jason.
Edited by jas/slo32
cheers Jason.
bare door weighs just over 3kg's
lexan windows $570 fitted.. not sure on weight as they are very light
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
