SAU:NSW Members Karting Dayaboutus.jpg
SAU has purchased 10 vouchers during a special deal
You get 3 x 10 minute sessions for $34!
How will it work? Book your spot and pay $34 to SAU just like any other event. This will guarantee you a voucher. We cannot book ahead due to the extreme discounting on the vouchers. SAU will call ahead to ensure the facility hasn't been rented out on our day.
If we cannot get in on our day, then we will reset another day a few weeks out. If you cannot attend you will get your voucher and you can go any time you like.
Event: SAUNSW GoKarting Day!
License: KartAtak does require you to have one of their special annual licenses. Available for $9 direct from them. IF YOU NEED A LICENSE, SHOW UP EARLY.
Date/Time: 9th Oct 10 AM
What is it: Indoor Go Karts on a purpose built track!
KartAtak rules and details can be found here. We are representing SAU at a public facility. Good behavior, judgement and compliance to their rules is expected.
Payment and details:
PM me(Pezhead) your mobile number after you've made payment. If we have to reschedule I'll directly SMS you.
SAUNSW bank details:
Bank - NAB
Branch - Marrickville
Account name - Skylines Australia NSW
BSB - 082 356
Account number - 546 393 766
Please put your FULL NAME in the description, eg "Karting JOE SMITH"
1) Owen - CPD
2) Brett - r32-25t
3) Aleck - Aleckr33
4)
5)
6)
7)
8)
9)
10)
Are you an SAU member and already have your own voucher? Come along for the day and have some fun with us!
https://www.sau.com.au/forums/topic/375271-saunsw-members-karting-day/
  • 3 weeks later...
SHUT UP
the XXL felt ok on the sides but pressed into my forehead painfully, but the 3XL fits nicely, feels secure and doesn't hurt (omg awesome). so i might pick up one there. only one in 3xl they had was white though, a faceless one. gay. i wanted the rjays tomcat :P
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
