  • Replies 54
Then R35 hands down.
Unless there is something about the R34 that you really must have????
I guess the performance of R35 is in a different league to the 34,
however............... i would still love to own a R34 as well! :)
Its just the raw sexyness and reputation and that keeps bringing me back to the R34.
Yes, Ive also heard you have to dump tens of thousands in to A R34 to bring it up to match the R35 performance.
But I want a R34 as close to standard as possible and I'll hold on to it. Already getting hard to find one which hasnt been 2 worked.
Stock for stock, the 34 is nowhere near the level of a 35.
The 35 is also the only car that has put a smile on my face without a clutch pedal, going from 35 back to an rb model you really feel the age of the 'old' gtr's.
For reference a stock 35 gtr does tsukuba in same time as z tune 34, which is regarded as the best goin street 34.
34 wins on price an maintenance though, unless u do it up you will not have maintenance costs like u see from r35.
For everything else, but pointless back seats, the 35 wins imo. So easy to drive, so fast, no lag, torque in any gear ( an amount you can only dream of from a rb ) great handling etc.
If money is not a problem I'd pick a r35 if I was you, the hype on them is well justified!!!
What cars are you coming from?
Hello, R33 GTR, R33 S2 GTST, 5x R34 GT-T, V35, Evo VII, Mercedes W211 E500, 350Z convertible, 350Z coupe. Thats all i can think of at the moment.
What i observed is the older nissan cars I've owned seemed 2 be better build quality than my newer nissans that ive had.
With my V35 and both of my 350z's I was getting sick of the power window faults, central locking faults, weak gearbox synchros, tears in the roof of the convertible - etc. All from design faults and sh*t parts. And u replace them with genuine spares which are also sh*t parts and its only a matter of time before it happens again.
With R34 u know the design faults already (stuff like rust around boot brake light). Im hoping that these similar issues i mentioned above dont pop up in the R35 over the next few years.
But R35 is such a sexy car aswell, they look fantastic every time i see them.
1318288390[/url]' post='6054986']
as a hobbiest detailer i couldnt fathom having my cars washed by low paid indian students, but then again everyone has diff priorities in life and some have other things to do instead of busting out the karcher etc on a weekend
nor would i simply high pressure the panels and then wipe all the dirt into the super soft nissan clear coat with a shamwow
op if you want someone to look after your car, shoot me a pm, i can recommend you a mobile detailer in your state who will do an at home wash
Would it be okay if they were low paid white-skinned students dominoz?
much respect to the R34 but you need a ride in the R35 - its godlike in every way
    • Pressure when IDLING, is meant to be 51PSi... So that amperage value needs to go up a fair chunk... I'd personally be factoring for more like 12amp at least on those runs, and at that point you need to hope the already there wiring doesn't drop you a volt or two, as that's a lot of fuel pressure flow drop off from 13.5 to 12V! Taking idle pressure of 51psi, means the pump will be drawing a MINIMUM of 9amps all the time based on your reading of the graph (3bar base, then allowing an extra 0.5bar for boost = roughly 51psi)
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
