Yay Sean - so are you gonna run at winton?
Nah, it'll probably throw a timing belt....coming up for a major!! >_<
It's not 'setup' anyways, just a heavy boat lolz.
You gotta give me a ride in your beast around Winton though!
  • Replies 551
Posted Images
doesn't the water in the shower water down the bourbon? I'm unfamiliar with a device that allows the water to not mix with the bourbon, is this a NSW thing?
It's much easier with these instead of an open glass that you mix yourself;
Negative captain. From what Ash was saying, there is no passenger rides while on the track (apart from the R35 hotlaps that will be prizes).
Love your ingenuity there, or is it just many years of experience talk'n. Regardless I always love the simple solution!
And yes Sean, because it is a timed event I don't think they will run passenger sessions. You're certainly welcome to hop in next time I take it to one of our days though.
That's what I do with my champers! Outside always!
Cccchhhhaaammmmppppaaaaaggggnnnneeee ssshhhhoooowwweeeerrrsss!!!!
Pat and i are booked @ the quest :)
Time to get our drink on!!
that's a shame! I think that if you don't enter today, you're screwed anyway :(
you can always buy a ticket and then if you aren't going to be driving, it can go to someone in the reserves list
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
