This is the 2011 MotoGP thread because much to my surprise we haven't got one.
Starting off, Casey Stoner cuts a pretty tidy lap to throw himself onto pole position for Misano tonight, who's watching ?
Anyone think Lorenzo can catch and pass Stoner over a race distance without some sort of bingle ?
Who will Simoncelli crash into this round ?
All these questions and more, ITT.
https://www.sau.com.au/forums/topic/376154-2011-motogp-thread/
  • Replies 486
Posted Images
I was gonna start a thread a while back, surprised there wasn't one this year..
Fell asleep and missed quali last night, but I'll be watching the first half of the race up until I have to leave for work, and the second half tomorrow...
Also, not to be discounted Moto2 is some of the best motosport on TV!!
Im a huuuuuuge Marc Marquez fan. which is strnage because typically i cant stand spaniards, but WHEN he makes it to MotoGP, ill be cheering him on as much as stoner.
Special shout out goes out to Crazy Jo too! lol the lewis hamilton of bikes
Stoner with the new lap record.
He annoys me though ever since he pretty much called rossi a hack. Casey 9 time world champions across various classes are not hacks you f**king idiot.
Maybe, but after Rossi & Burgess spent months telling anyone who'd listen that Stoner hadn't ridden the Ducati to its potential; in spite of the fact he's the only rider to consistently win on it. And for all the big talk in the pre-season, they've produced precisely nothing in the way of results.
They've been pretty quiet about his ability lately...
Rossi's no hack; that's for sure, but he's closer to the end of his career than the start.
Edited by Daleo
